[C2] Hard fuel line, fuel pump to carb question
Mar 27, 2026 | 05:03 PM
I want to replace a braided fuel hose with 5/16” OE steel hard fuel line from stock fuel pump to a single feed Holley 4bbl 4160 carb
Can anyone help me figure out what fittings I need for the carb fuel inlet?
Some sources say it’s 7/8”-20 and others say 9/16”-24.. and how to attach the 5/16” hard line to it?
Mar 27, 2026 | 05:22 PM
2015 C2 of Year Finalist
You might be better off getting the 64-65 L76 and L79 set up
Mar 27, 2026 | 06:15 PM
Sorry, should’ve stated it’s a 1966 base 327/300.
Trying to keep it as stock as possible… but not NCRS level car.
Mar 27, 2026 | 06:26 PM
Then your going to need to source the correct fuel bowl
Mar 27, 2026 | 06:54 PM
Do you mean a fuel bowl for a Holley 3367 which is the correct Holley for a 66 327/300 and put it on the 4160?
or is there a fuel bowl for a 4160 that can accept a 5/16 hard fuel line?
Mar 27, 2026 | 07:01 PM
the 3367 is a holley 4160 carb
Mar 27, 2026 | 07:18 PM
Ok, so get a 3367 front bowl and swap it out with
my 4160 (80457)?
Mar 27, 2026 | 07:26 PM
Yesterday | 06:17 PM
Done! thanks for you advice!
