C3 Parts for Sale/Wanted C3 Corvette Performance Parts, Rare NOS and NLA Chevy Parts, Wheels & Tires, Exterior Enhancements, Aftermarket
Late79-82 AM/FM/CB power antenna
Old Mar 31, 2026 | 07:47 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Default Late79-82 AM/FM/CB power antenna
New nylon cable installed in a nice used antenna out of a low mile 79,
The outer mast tube is dented from someone elses attempt to fix, just cosmetic and will be hard to see when installed,
Mint antenna sections and nice load coil.
Operates like new.
$300 shipped.
Old Apr 30, 2026 | 04:19 PM
LS6 Motor's Avatar
LS6 Motor
CB antenna, mine is just AM/FM
Old Apr 30, 2026 | 05:22 PM
KapsSA's Avatar
KapsSA
OK..........
Thanks for the bump
Old May 13, 2026 | 07:30 PM
KapsSA's Avatar
KapsSA
bump
Old May 13, 2026 | 09:45 PM
rasaro@msn.com's Avatar
rasaro@msn.com
Will it fit a 1978? I would llike to purchase.
Thanks
Old May 13, 2026 | 10:00 PM
rasaro@msn.com
After doing some research I believe it will fit a 1978, is it still available?
Thank You
Old May 13, 2026 | 11:51 PM
KapsSA's Avatar
KapsSA
It will fit a 78 but is not "correct".
78 has a different fit at the fender, will need beveled spacer under the chrome bezel as the 78 has a smooth opening with a snap in black bezel and 79 uses chrome bezel to attach instead of the upper bracket used on 78.
I believe I do have a bevel spacer and correct lower bracket.
It is direct wire in but you would need to cut and splice wires as 78 does not have the connector.
Still interested?
To Late79-82 AM/FM/CB power antenna
