C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] It has begun
Old Apr 10, 2026 | 09:50 PM
JetStreamButterfly's Avatar
JetStreamButterfly
Default It has begun
I put down a deposit with Mamo Motorsports on Wednesday.
Mamo Motorsports Stage 2 Ported Heads
Mamo Motorsports Stage 2 Camshaft
YT Ultralite rockers
Johnson Lifters
Manton Rods
Timing Chain Set
MSD Intake Manifold
ARP Head Studs
(This combination should make 575 rwhp on 91/93 Octane Pump Gas per Tony Mamo).
I absolutely cannot wait!
Old Apr 10, 2026 | 09:55 PM
SPDKLZ1's Avatar
SPDKLZ1
Johnson Lifters
Manton Rods
Timing Chain Set
MSD Intake Manifold
ARP Head Studs
Congrats! It's going to be a reliable beast!
Old Apr 11, 2026 | 12:14 AM
Hib Halverson's Avatar
Hib Halverson
Pro Mechanic
Pro Mechanic
Tony's stuff is awesome. You picked the right guy from whom to buy those mods.
Old Apr 11, 2026 | 08:13 AM
Dreamer2's Avatar
Dreamer2
What does something like this cost?
Old Apr 11, 2026 | 09:53 AM
grinder11's Avatar
grinder11
You'll never be sorry. Tony is the best.
Old Apr 11, 2026 | 07:06 PM
JKNAPP's Avatar
JKNAPP
Johnson Lifters
Manton Rods
Timing Chain Set
MSD Intake Manifold
ARP Head Studs
What are the cam specs?
Old Apr 11, 2026 | 07:43 PM
JetStreamButterfly
About $10K just in parts.
Labor for heads/cam/intake install should be around $5.5K - $7K depending on the shop and rates.
He hasn't given me the specs yet.
Old Apr 12, 2026 | 01:06 PM
NA FURY's Avatar
NA FURY
You should be comfortably under $5k for the install.. not sure where you're getting that range from.
Old Apr 12, 2026 | 01:10 PM
WeaponsGradeTorque's Avatar
WeaponsGradeTorque
Johnson Lifters
Manton Rods
Timing Chain Set
MSD Intake Manifold
ARP Head Studs
Congrats! What is the difference between the stage 2 and stage 3 heads?
Old Apr 12, 2026 | 02:26 PM
shawng89's Avatar
shawng89
Johnson Lifters
Manton Rods
Timing Chain Set
MSD Intake Manifold
ARP Head Studs
You made a great choice. I also have a Mamo build in the works.
Old Apr 12, 2026 | 04:46 PM
Tony @ Mamo Motorsports's Avatar
Supporting Vendor
Expensive lightweight custom Ti intake valves and Ferrea hollow stem exhaust valves in the Stage 3
My Stage 1 and Stage 2 heads come with lightweight hollow stem Ferrea intake valves and solid stem exhaust.
Both valves weigh about a 100 grams and I have many guys with larger cams and more aggressive combo's turning up to 7500 RPM with those heads.
I would estimate that eight out of ten sets of LS7 heads I sell are my Stg 1 or Stg 2 heads and they run hard and perform great....my Stg 2 heads are arguably the biggest bang for the buck. Lots of optional equipment (spring upgrades etc.) and additional porting at a reasonable price.
Point is the Stg 3 is optional....really more for the guys that have a fairly large mod budget and want to get every last bit of power. Or builds that are very aggressive with large cams and short runner intakes trying to turn in excess of 7500 RPM's
The Stg 3 valves are also a little larger (but still lighter due to the material they are made of). The intake valves are 2.230 vs 2.205......1.615 vs 1.600 on the exhaust
I go into detail about this and all the other options when Im discussing the overall build with my clients and have a better idea of their budget and what they are trying to achieve
If you (or anyone reading this) are considering working with me on a project give me a call and we can discuss everything in much greater detail and go over all the pricing as well
One of my milder Stg 2 grinds for a very balanced power curve and excellent drivability
231 intake lobe.....245 exhaust......I did share this with the OP but we talked about so many things she likely forgot.....LOL
I supply a cam card with all my customer builds.....nothing is secret or purposely hidden
Regards,
Tony
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
Old Apr 12, 2026 | 08:37 PM
JKNAPP's Avatar
JKNAPP
231 intake lobe.....245 exhaust......I did share this with the OP but we talked about so many things he likely forgot.....LOL
Regards,
Tony
I bought my Z06 with a 234/246/112.5 (109.5 intake center line).....Car surges a good bit below 3k?
Old Apr 12, 2026 | 11:41 PM
JetStreamButterfly
Ripoff shops on the Front Range here trying to take advantage of people.
Automotive labor rates have skyrocketed here between $200 - $265 an hour.
Old Apr 13, 2026 | 04:31 AM
Supporting Vendor
Your cam has 15 degrees of overlap....its more aggressive....closer to a Stg 3 than a Stg 2
That said there should be zero surging till 1500 at the most with a cam that size.
It could be mechanical (issues with the engine or install) or it could just be a really poor tune but that's not a big cam and it shouldn't do anything funny till much lower RPM's.
I would recommend you have a different shop put eyes on it and see if they can improve things for you
Good luck
-Tony
Old Apr 14, 2026 | 08:23 AM
double06's Avatar
double06
I think you will be very pleased with your selection here on vendor and parts but it will not matter if you do not have a good tune. So focus on that too. I hope you have a good clutch. If you are in a heavy traffic area get one with a heavier flywheel to help with the Moment of Inertia at stop lights.
Old Apr 14, 2026 | 08:52 AM
JKNAPP's Avatar
JKNAPP
Good luck
-Tony
The car surges below 3,000 RPM, cleans up after that....what motor issues would cause this? Appreciate your help.
Old Apr 14, 2026 | 11:58 AM
JetStreamButterfly
can you like make your own thread and stop hijacking mine please?
To It has begun
Old Apr 14, 2026 | 12:08 PM
JKNAPP's Avatar
JKNAPP
Wasn't trying too...
Old Apr 14, 2026 | 12:29 PM
blckss's Avatar
blckss
I have a MAMO package (Probably more like a Stage "2.5"), as Tony worked with me for a Road Race freindly setup, not all out max effort.
That being said, it's a beast at 617rwhp - and the weight down to around 3,050# dry (weighed at track low on fuel). I am very happy, and you will be too!
I'm going to have to detune the setup in order to run TT1 class. And it still has tags.
Old Apr 14, 2026 | 04:16 PM
WeaponsGradeTorque
great feedback. Is the 617 rwhp SAE or STD? Dynojet?
