C8 Grand Sport Discussion General Grand Sport Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Center Exhaust
Old Apr 17, 2026 | 06:00 AM
plake's Avatar
plake
Default Center Exhaust
Is the center exhaust option really $2K? Am I seeing that correctly?
Popular Reply
Apr 22, 2026, 05:22 PM
V8NTRNK's Avatar
V8NTRNK
I swapped out my Stingray's Z51 "performance exhaust" with a Z06 center exit exhaust. This swap also involved replacing the lower diffuser with a Z06 diffuser as well as a few other parts but basically it bolts right in without any major modifications to anything. All in the cost was just over $2100 for everything needed. I turned around and sold my old exhaust and diffuser for $500 which lowered my overall cost to $1600. It definitely sounds better/louder and as others have said, it puts more sound into the cabin of the car, plus it's still technically OEM. That being said, the $2000 option seems reasonable to me.
Old Apr 17, 2026 | 06:18 AM
SULLY2013's Avatar
SULLY2013
That's the way I saw it as well, it's such a cool look but for $2k I will keep the side exits and be happy with it.
Old Apr 17, 2026 | 07:02 AM
plake's Avatar
plake
I wonder if the sound from the center exhaust is better thought I saw that somewhere.
Old Apr 17, 2026 | 08:27 AM
Twenty7GS's Avatar
Twenty7GS
Yeah they definitely are reaching at that price. I’m gonna pay it because it looks, and allegedly sounds, better
Old Apr 17, 2026 | 08:28 AM
TorchZ51's Avatar
TorchZ51
It’s being reported the Center exhaust has a more aggressive sound than the base side exhaust setup. Given the cost of aftermarket, the center exhaust is a bargain for the sound along with the aesthetics.
Old Apr 17, 2026 | 08:36 AM
DWS44's Avatar
DWS44
2022 C8 of the Year Finalist - Modified
2022 C7 of the Year Finalist - Unmodified
That's the price I've seen two different dealers price lists, so have to assume it is correct. Higher than I expected, but I've wanted one all the way back to when the Z06 first introduced with. Just like the look better, and any sound improvement would be icing on top. Someone can correct me if I'm wrong, but I don't think you'd find many aftermarket C8 exhausts, certainly not center-exhaust conversions, for $2K or less.
Old Apr 17, 2026 | 01:25 PM
Ryder2020's Avatar
Ryder2020
probably not. And if you go to center exhaust, you have to change the rear diffuser, also, but everything goes zo6, then the rear diffuser is a stock z06.The exhaust is stock z06
Old Apr 17, 2026 | 02:40 PM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
Yes and I think it comes with black tips because there’s no option for black but is one for bright tips.
NEW'Exhaust tips, bright, center, quad, exposed
Req. WUB
$395
Old Apr 17, 2026 | 02:46 PM
Rob Willis's Avatar
Rob Willis
Black tips are standard on all Stingrays, GSs, Z06s, etc in 2027 I "think".
Old Apr 17, 2026 | 02:59 PM
Misty C8 Z06's Avatar
Misty C8 Z06
The options feel like they are high markup?
Old Apr 17, 2026 | 04:04 PM
Korbek's Avatar
Korbek
Req. WUB
$395
This right here is the confusing bit. No way "bright" center exhaust is $395 and "black" (aka standard) center exhaust is 2k.
Far more likely scenario is that 2k is for center exit, and if you want "bright" (likely polished chrome) center exit it is ANOTHER $395 on top of the 2k center exit option. Time will tell.
Old Apr 17, 2026 | 04:51 PM
ICONIC7's Avatar
ICONIC7
2025 C7 of the Year Finalist - Modified
2023 C7 of the Year Finalist - Modified
As far as the tip colors, black is standard and chrome is the upgraded option.
Old Apr 18, 2026 | 04:31 PM
Al Engel's Avatar
Al Engel
Default Trunk space with center exhaust
Anybody know if the center exhaust affects the depth of the trunk vs the "standard" exhaust routing to the rear corners? I think I read somewhere when the Z06 first came out, someone commented the trunk depth was impacted by the center exhaust.
Al Engel. "Save the Wave"
Old Apr 18, 2026 | 06:37 PM
gtpvette's Avatar
gtpvette
I had a 23 SR now a 25 Z06. I dont see any difference.
Old Apr 19, 2026 | 08:34 AM
Al Engel's Avatar
Al Engel
Thanks fot your input.
Al
Old Apr 19, 2026 | 10:13 AM
Twenty7GS's Avatar
Twenty7GS
it’s not that confusing. It says requires WUB. That’s center exhaust. So yes you are right that it’s 1995 plus 395.
Old Apr 20, 2026 | 09:46 AM
davelv's Avatar
davelv
Will center exhaust lead to higher temps in the trunk?
To Center Exhaust
Old Apr 20, 2026 | 12:18 PM
ClothSeats's Avatar
ClothSeats
I asked that question a while back on the C8 General forum. The replies that I got from owners that have had both types of exhaust is that there is no discernable difference in trunk temperature.
Old Apr 20, 2026 | 02:48 PM
akq's Avatar
akq
Do we have any confirmation that center exhaust is louder / has a different tone? If it is just for the looks I am not paying $2k. $2K can go a long way towards a proper aftermarket exhaust.
Old Apr 20, 2026 | 03:05 PM
davelv's Avatar
davelv
Go to chevy website for the GS and they have a sound clip of the exhaust.
Bigger issue I see is your legs get burnt if getting something out of the trunk with engine running.
