[C2] Will I have a cross-fire problem with the way my spark plug wires are arranged?
Picture 1 - taken from the 67 AIM
Picture 2
While the NCRS may have some evidence that supports the S/P wires being arranged in the rubber grommet as shown in picture 3, I have chosen to arrange my S/P wires as shown in pictures 4 and 5.
Picture 3 - NCRS arrangement
Picture 4 - My preferred arrangement
Picture 5 - my preferred arrangement
I was recently made aware of a cross-fire issue running S/P wires #5 and #7 in contact with each other but I admit that I do not know if this issue happens BEFORE or AFTER those S/P wires exit the rubber grommet. Before I fire up the engine again, I want to do what I can to ensure I won’t have this cross-fire problem with my S/P wires arranged as they are.
Here is how I currently have my S/P wires arranged in the rubber grommet. Could this arrangement result in that cross-fire problem?
Insulation on the wire, if it's of good quality and in good condition, will prevent the spark from instead breaking through the insulation to anything adjacent.
If a leaky insulator does permit arc-through, odds are it will occur within the more lengthy portion of the wire that is within the braided shield (which is a dead short to ground) than in the relatively short portion that is unshielded.
That energy is far less likely to break through the insulation on both the wire in question and an adjacent wire, and then pass through the series (additive) resistance of the adjacent wire's core, the resistor in that spark plug and the gap across that spark plug, than it is to go where it's supposed to or anywhere else.
If your wires and plugs are of high quality and in good shape, and the plugs are properly gapped, the insulation on the wires should be able to contain the spark energy with no trouble.
Live well,
SJW
Your NCRS 4-square placement is from GM (in the AIM). GM also put the #5 wire, in the 4-across valve cover holder, in the forward most fingers and #7 in the rear most fingers. I don't know how spark plug wires of 1967 compare to what's available today, so maybe it's a moot point and a rare occurrence.
Live well,
SJW
As an electrical engineer, I have always assumed that crossfire between two adjacent ignition cables was due to electromagnetic induction rather than insulation breakdown.
If two wires are run in parallel for a long distance, an impulse current in one wire will induce a corresponding voltage in the adjacent wire (this how transformers work, coupling energy from one wire to a separate wire from which it is fully insulated). Good induction coupling requires that the two wires run in parallel, very close to each other, for a long distance. Cables that cross at right angles have almost no induction coupling at all, and cables that are far apart (say, one or more inches) have very little induction coupling.
I suspect that GM's routing scheme for plug wires was to minimize induction coupling by avoiding long parallel cable runs for cylinders that were close in the firing order. I've never looked closely enough at GM's routing to verify this, but I suspect that is what I would find.
perhaps GM separated them for a reason…
A premature spark on a cylinder that is on its exhaust stroke would not cause a problem.
If we look at just the pairs of cylinders that are directly in sequence, we have 1-8, 8-4, 4-3, 3-6, 6-5, 5-7, 7-2, and 2-1. Most of these pairs are on opposite sides of the engine, but 8-4 are both on the passenger side and 5-7 are both on the driver side. So, these are the pairs in the firing sequence that run the longest distance in parallel.
On the passenger side, cylinders 8 and 4 have cylinder 6 between them, which may help to keep them separated. On the driver side, cylinders 5 and 7 are immediately adjacent. So, in terms of potential inductive crossfire, it appears that cylinder 5 coupling into cylinder 7 presents the highest risk.
That may be why GM made an effort to provide extra separation between those two wires.
This is all conjecture on my part, but my conjecture is based on the physics of insulation breakdown (unlikely) and electromagnetic induction (plausible). Either of these two mechanisms could lead to crossfire, but if the cable insulation is in good physical condition, insulation breakdown is very unlikely.
From the '67 AIM, this shows the shielded wire pairs under the valve cover bolts. You can see the crisscross of #5 & #7 in the square rubber holder, but the straight-4 holder has them next to each other.
The '69 AIM best shows the placement of what wire number goes in which hole of the rubber squares - this is for both the L-36 and L-71.
From the '72 AIM, you have to trace the black, striped, white wires to see placement in the straight-4 holder. This is the LS-5, which was quite similar to the L-36.
Owen, for days I studied magnified illustrations from the 67 AIM and traced all the S/P wires back to the distributor through the 4 hole rubber grommets, for days... Eventually, I threw my hands in the air and said "I'm gonna do the best I can and go with it." It won't be much longer before I can fire up my car again and I can report back to the forum HOW I have my S/P wires and if I experienced any problems such as a cross-fire.
A SBC with the hockey stick shields presents a different scenario, but I've never heard of it causing a problem, and GM obviously wasn't too concerned about it.
Live well,
SJW
Live well,
SJW
I think the primary risk for crossfire among the cables is induction. That risk can be lowered by carefully minimizing long, close proximity, parallel cable runs for cylinders that are adjacent in the firing order. For the case where these long parallel cables are shielded, the shielding will likely reduce the inductive coupling, but the analysis of that scenario is complicated.
