Easy balancer replacement.
Old Apr 18, 2026 | 10:13 AM
Jonnygun's Avatar
Jonnygun
Default Easy balancer replacement.
Good news!
I replaced my balancer without dropping the sub-frame or removing the steering rack. I wanted to share it with anyone who is dreading the job.
I found this video on YouTube, it is brief and lacks some details but it looked like a much easier alternative to the 2 common methods.
https://m.youtube.com/watch?v=Sq-e462nrEI
So I replaced mine yesterday, took me about 6 hours including 2 trips to the store to pick up some deep sockets I didn’t own.
Here is the process:
Turn wheels to the right and remove the boot and passenger side tie rod.
Remove fan assembly.
I removed the air intake parts to replace my belts.
Remove passenger side rack mounting bolt and loosen driver side bolt.
I laid a 2x4 across the engine bay and used a ratchet strap to hold the rack up just enough to get to the crank bolt. There is enough room to remove it and pull the crank pulley.
I installed the crank seal, new pulley and pinned the crank.
I’m pretty sure with access to a lift instead of jack stands this is doable in 3-4 hours.
Old Apr 19, 2026 | 10:06 PM
Corvette_Dez's Avatar
Corvette_Dez
Awesome! Thank you for sharing.
Old Apr 19, 2026 | 11:19 PM
RoverJoe's Avatar
RoverJoe
I did it once for a friend, and left the rack in the car as you suggest, just unbolted and lifted up out of the way. We were in a shop on a lift and it was not a bad job at all.
Old Apr 21, 2026 | 09:01 PM
schizcat's Avatar
schizcat
Did you unbolt the power steering lines or remove the tie rod?
Old Apr 22, 2026 | 05:42 AM
Spaceme1117's Avatar
Spaceme1117
I'm sure every job is easier on a Corvette with a lift. Sigh.
Old Apr 22, 2026 | 08:53 PM
RoverJoe's Avatar
RoverJoe
Almost any job on any car. When I was a young buck I pulled engines, did clutch jobs, whatever it took all in my dads driveway on my back. Now, after 20 years working in shops, you couldn't pay me enough to do that heavy work on the floor. I did a clutch on a Fiat 500 for a buddy the other day, in a friends shop with a lift, and there's still almost no amount of money that would make it worth doing. I must be getting old.
Old Apr 27, 2026 | 09:40 AM
PCMusicGuy's Avatar
PCMusicGuy
I like that you said that you didn't have to remove the steering rack and then proceeded to explain that you had to "remove" the steering rack. Regardless, I'm glad you got it done.
Old May 12, 2026 | 04:35 PM
JKNAPP's Avatar
JKNAPP
Great info, as I will be doing this again shortly
Old May 24, 2026 | 06:56 PM
Jonnygun's Avatar
Jonnygun
Default Balancer replacement.
I did not remove the rack, I merely removed the passenger side bolt and loosened the driver side so I could rotate it up and out of the way.
Power steering lines were not disconnected nor was the column linkage. This is moving the rack, not removing it.
Old Yesterday | 08:48 AM
double06's Avatar
double06
Good thinking and helpful ideas on how to do that job. For crank bolt did you use a impact or a long pry bar. Was this on a dry sump motor. If not anybody know if this process would work on dry sump motor as the balancer in the front is different.
Old Today | 05:46 PM
Jonnygun's Avatar
Jonnygun
I used an impact to remove the old bolt, I used a torque wrench to tighten the ARP bolt to 235 ft lbs.
My car is a 2006 base so no dry sump but I believe the process will work on a dry sump car.
To Easy balancer replacement.
