Movement in the driveline
Old Apr 18, 2026 | 11:07 AM
Impala Balko's Avatar
Impala Balko
Default Movement in the driveline
I've noticed when I get on it the driveline moves a little bit because the shifter feels like it moves up maybe a half inch... when I installed the new boosted 383 I put in new motor mounts. The car is a 94 6 speed making about 500 ft lbs of torque to the wheels and close to the for horse power... is this normal or should I try a different set of motor mounts or possibly solid mount it if they make them?
Old Apr 18, 2026 | 12:06 PM
CorvetteRules's Avatar
CorvetteRules
Did you check for play in the universal joints?
Old Apr 18, 2026 | 12:22 PM
s carter's Avatar
s carter
It's fairly normal to have a bit of movement up and and even side to side especially on Hi HP use, but to take any normal to abnormal you did step 2 already step 1 is the Torque arm beam (C channel) is properly tightened.
There will be movement a bit because as the name implies Torque arm as power is put down the differential will want to twist which goes down the beam to the transmission.
Old Apr 18, 2026 | 12:32 PM
MatthewMiller's Avatar
MatthewMiller
This is 100% due to your C-beam bolts not being tight enough at the transmission tail shaft side. I had the same thing happen. There should be no up-down movement of the shifter at all.
Old Apr 18, 2026 | 02:31 PM
dizwiz24's Avatar
dizwiz24
i know this bc ive done this (not had them tight enough)
do it before the c beam bolt holes ovalize
Old Apr 18, 2026 | 02:57 PM
Impala Balko
the Cbeam bolts felt tight when I put the car back together using the german torque method... what is the propper torque specs I'll give them a once over.
Old Apr 18, 2026 | 02:59 PM
Impala Balko
the U joints on the driver shafts seemed pretty tight when I reinstalled them.
Old Apr 19, 2026 | 06:37 AM
Desert Rider's Avatar
Desert Rider
Proper torque for the C-beam bolts is very important
Old Apr 19, 2026 | 07:45 AM
MatthewMiller
For my 96, the Factory Service Manual says the C-beam (they call it "Driveline Support") bolts to the transmission should be 37 lb/ft and the beam-to-diff should be 59 lb/ft. I'm going to tell you that's not enough. Keep in mind that on my car, at least, GM also put some goop in there to help keep things from shifting around. I don't recall how tight I made mine, but they were a lot tighter than that.
Old Apr 19, 2026 | 10:11 AM
Torqsplit's Avatar
Torqsplit
Same here. Even after torquing to spec at 1st install, they ALL needed a retorque less than 500miles later. & Half of that was very casual driving. It's tough to access the bolts w/ factory exhaust in place, but worthwhile to loosen & lower enough to snug em back up 👍🏻 Def don't want to leave it loose and cranking around. Might be a recurring check on your build at those power levels 💪 🍻
Old Apr 19, 2026 | 06:58 PM
Impala Balko
So should I loosen all 4 then retighten them or should I just torque them how they are
Old Apr 20, 2026 | 10:49 AM
Torqsplit's Avatar
Torqsplit
Yes, I would back them off a bit, not fully loose but partially. And then go to spec. This way you have a known baseline. I feel the rear torque spec felt adequate/ appropriate when I did mine, but the front seemed pretty low by comparison. I inquired with ZFDOC about it, cause I used his Beam Plates, and he cautioned against any extreme over tightening as it can distort the tail housing and cause binding. Made sense, the mounting is less beefy on the transmission. On my 2nd retorque I went a bit higher, maybe mid ~40's lb/ft. Good for now 👍🏻 Sadly it seems like a more frequent retorque is the safest policy for me, vs cranking it down possibly too much 🤷‍♂️ Not to challenge anything Matt Miller offered for his setup. I'm curious what #'s you ended up using to keep things locked down?
Old Apr 20, 2026 | 07:48 PM
MatthewMiller
No worries about that: if you have good info from a good source, then by means post that. I would defer to ZF Doc any time! It's been so long since I pulled the transmission, and I no longer own a C4, so I can remember at all where I ended up. I did use his beam plates, so I don't know if that makes a difference.
Old Apr 21, 2026 | 02:07 PM
wolf_walker's Avatar
wolf_walker
With the TKX in my 86 and the shifter being rigidly bolted to the trans I noticed first off how the driveline flexes up/down.
It's a lot of weight and stress on a piece of aluminum, and it's not even when accelerating just with undulations in the road you can
feel the trans following the chassis a split second behind in sort of a springy/flexy motion. It's really kind of interesting to watch.
Never felt or noticed anything on hard acceleration but I don't have any power to speak of either so hey.
And no nothing is loose.
Old Apr 21, 2026 | 11:15 PM
Desert Rider
Well .. nothing moves on my low mileage 1996 coupe.
Old Apr 21, 2026 | 11:34 PM
wolf_walker
After 40 years and 160k it apparently does.
Old Apr 22, 2026 | 08:53 AM
Desert Rider
The connection between the transmission and differential should be rigid. I would look at motor mounts and batwing bushings.
To Movement in the driveline
Old Apr 22, 2026 | 09:21 AM
wolf_walker
Motor mounts are new and the batwing bushings appear to be hard as a rock, which no doubt indicates needing replacement but they aren't loose.
I would bet a significant amount it's the C beam flexing. I suppose it could be the motor mounts compression but it seems like that would exhibit some
other symptoms, and they are new. It is a very rubber-band feeling at the shifter and on only specific movements of the chassis.
You'd never feel it with the 4+3 since the shifter is body mounted and the later ZF cars may not exhibit it from all the differences vs an early one.
It's probably less than a quarter inch but there is a definite "bounce" there.
Also there does not seem to be any movement going hard and fast on and off the throttle, it's just when there's a big enough dip in the road
for the chassis as a whole to compress fairly evenly. It's really not especially objectionable but I thought it was interesting.
Old Apr 22, 2026 | 12:58 PM
MatthewMiller
Two things I can imagine: 1) The shifter could rock side to side a bit as the engine and diff twist in their mounts, and 2) It might move a bit over certain kinds of bumps. The C-beam is designed to allow some twist, but not any vertical bending at all. The beam is more than enough to prevent vertical movement of the tailshaft, even when I put over 400rwhp (on a pretty torquey engine) through it to 315 Hoosier A7 tires on 17x11 wheels...except for the time I didn't have the bolts tight enough.
Old Apr 22, 2026 | 01:09 PM
wolf_walker
No side to side movement that I can detect, and nothing I can feel with a hand on the shifter while accelerating or decelerating hard.
The shifter on these is extremely rigidly mounted and tight, way more so than any of the stock ones. It telegraphs every little noise and movement
of the driveline right up into your hand.
Only time it's noticeable is when just cruising and the weight of the whole car smoothly comes down evenly in a shallow gulley in the road, then
the shifter kinda springs down for a split second and back up. Sometimes it'll sort bobble up and down on the right type of crappy
road (we have major crappy roads here). It's not extreme but I noticed it after the trans swap. Nothing is moving, something is flexing.
The C beam bolts are not moving, if they were it wouldn't be springy like it is. Could be old age and mileage.
It's possible it's an early car thing, you'd never notice with the 4+3 shifter and the later ZF cars just don't do it for whatever reason.
