Autocrossing & Roadracing Classifieds Post your For Sale or Wanted Autocrossing & Roadracing parts here.
FS: 1999 Spec Corvette / SCCA T2 road race car for sale
Old Apr 22, 2026 | 10:29 PM
clubracer23's Avatar
clubracer23
Default 1999 Spec Corvette / SCCA T2 road race car for sale
1999 Spec Corvette / SCCA T2 race car with TrackSpec SCCA/NASA legal roll cage kit installed. Clean Arizona title and SCCA log book. Kline Racing Engines built LS6 engine (from a 2004) with forged flat-top pistons and ARP rod bolts. Two piece batwing oil pan with Improved Racing trap door baffles. Four corner steam ports. Motion Raceworks catch can system. Rebuilt close ratio transmission with steel shift forks, bronze shift fork pads, billet chromoly synchro keys, billet guide bolts/pins and carbon synchro rings. TMOD Customs 15% reduction shifter with TMOD Customs rebuilt lower shift box and rebuilt shift linkage. Rebuilt torque tube with new couplers, bolts and bearings. Rebuilt 3.42 rear differential with new LSD clutches and thrust washers. Spec Corvette Wilwood front big brake kit. Spec Corvette single-adjustable, remote canister Penske coil-over shocks with Eibach coil springs and TrackSpec sway bars, TrackSpec Delrin control arm bushings, AMT camber kit. Big ECP aluminum radiator, Setrab engine oil cooler, Ram aluminum flywheel with LS7 clutch, push button start kit, painless performance kill switch kit, NRG steering wheel, New Momo FIA seat and new OMP belts good until 2030. 10# SFI fire suppression system. Four 18x11 Apex EC-7 wheels with good used Vitour P1 tires. Cat delete down pipes with NXT Step Performance X-Pipes and C5 Z06 Titanium mufflers. SKF X-tracker hubs. 2009-2013 C6 brake master cylinder and brake booster upgrade. OEM ABS works flawlessly. $35,000.00 in Phoenix, Arizona
Old May 8, 2026 | 09:23 PM
clubracer23
Bump, price lowered to $32k.
Old Today | 04:15 PM
clubracer23
Sold, THANK YOU Corvette Forum!
To 1999 Spec Corvette / SCCA T2 road race car for sale
