C8 Parts for Sale/Wanted C8 Corvette Performance Parts, OEM, Aftermarket, Superchargers, Turbo Kits, Wheels & Tires, Exterior Enhancements
Sponsored by: C7 Carbon
FS: Borla S-Type Catback Exhaust for C8 Stingray
Old Apr 25, 2026 | 08:55 AM
dman918's Avatar
dman918
Default Borla S-Type Catback Exhaust for C8 Stingray
Hi all,
Up for sale is my Borla S-Type catback for the Stingray. It includes both the AFM and NPP connections. I had it on my car for about 6k miles. In good overall shape. There is a small ding on the topside of the muffler (can’t be seen when installed) and it is missing one of the heat shields ($212 if you want a replacement from Borla). Everything works great and it adds a wonderful exhaust note to the car. Deep and aggressive.
Located in Algonquin, IL. Will ship at buyers expense.
Looking for $2750. Please message me with any questions.
Thanks,
Mike
Old Apr 27, 2026 | 08:42 AM
87Z52's Avatar
87Z52
I notice on Borla's website they say to not install these on cars that don't have factory NPP. What's the issue with that? Won't the valves just stay open all the time? Or is there another problem?
Old Apr 27, 2026 | 09:17 AM
dman918's Avatar
dman918
Sorry I’m not sure. Best to call Borla to ask.
Old Apr 27, 2026 | 10:43 AM
dman918's Avatar
dman918
I went ahead and called Borla for you. They said that it would likely work, but they would not recommend it because if the valve did end up getting stuck closed or something like that, you would have no control over it. Basically they were continuing to say they just don’t recommend it because you would not have control over the valves. It did sound like it would work though.
Old Apr 27, 2026 | 10:51 AM
87Z52's Avatar
87Z52
Thanks, I just wrote them too. Are the valves spring-loaded such that they are open by default? That was always my understanding of how the factory NPP exhausts worked. I would assume the aftermarket ones are similar. Are the C8 NPP controls still vacuum or are they electronic now?
Old Apr 27, 2026 | 11:19 AM
dman918's Avatar
dman918
When I get home I can take a pic of the valves. I’m pretty sure they’re electronically controlled but maybe an expert can chime in.
Old Apr 27, 2026 | 11:30 AM
87Z52's Avatar
87Z52
I just heard back from them. They said the valves would be "flapping in the wind" and making a lot of noise. They must not use a vacuum actuator like the older-gen NPP. Those were held closed with spring tension until the vacuum solenoid opened them. Sounds like these operate differently now.
Old Apr 29, 2026 | 03:23 PM
C7Me's Avatar
C7Me
Purveyor of Common Sense
St. Jude Donor '19
What heat shield is missing? I'm local, so just curious who installed it for you?
Old Apr 29, 2026 | 07:13 PM
dman918's Avatar
dman918
Hi,
it’s the black shield that covers the center pipes. Not needed but some people prefer it for added heat resistance. Crystal Lake Brake and Auto installed it for me.
Thanks,
Mike
Old May 3, 2026 | 03:33 PM
dman918's Avatar
dman918
Nevermind
Old May 9, 2026 | 06:57 PM
dman918's Avatar
dman918
Looks like the guy backed out. Back available.
Old Today | 11:18 AM
C7Me's Avatar
C7Me
St. Jude Donor '19
Can you change the tips on this system?
Old Today | 11:46 AM
Meklam's Avatar
Meklam
Cruising
Lmk if it’s still available!
Old Today | 02:58 PM
dman918's Avatar
dman918
Tips are welded so you would remove and weld new tips on. I believe I’ve seen some threads on people doing it.
Old Today | 02:59 PM
dman918's Avatar
dman918
Yes, PM’d you.
To Borla S-Type Catback Exhaust for C8 Stingray
