Was the next thing on your to do C4 list
Old Apr 26, 2026 | 03:56 PM
BET VETTE's Avatar
BET VETTE
Default Was the next thing on your to do C4 list
Old Apr 26, 2026 | 07:55 PM
Whaleman's Avatar
Whaleman
This Fall I would like to remove my rocker panels and have them painted. Dan
Old Apr 26, 2026 | 09:03 PM
Natty C's Avatar
Natty C
2022 C4 of the Year Finalist - Unmodified
2021 C4 of the Year - Unmodified Finalist
I'm thinking probably new paint.
Manly because it's somethng I don't have to do myself, so the timing is good in that regard.
Old Apr 26, 2026 | 09:21 PM
2011KLR's Avatar
2011KLR
I due an OD fluid change and tire rotation.
Old Apr 26, 2026 | 11:45 PM
Steve Swan's Avatar
Steve Swan
1994 LT1 1996 LT4
In the process of installing an auxiliary cooler for my LT1 auto.
Old Apr 27, 2026 | 12:03 AM
RustyDuster's Avatar
RustyDuster
Fixing those door panels... ugh.. Mine don't have the inner ribs so I can't use the "zip tie method". I'll need to employ something else. Also, need to figure out why the lateral adjustment on my mirrors won't work. Replaced switch and the motor operate but it's gotta be something! Right I'm on vacation though so Im hittin the water tomorrow!
Old Apr 27, 2026 | 12:33 AM
Crabs's Avatar
Crabs
Active Streak: 90 Days
Install the ZFDoc short shifter that I've had on the shelf for over a year.
Crabs '90 ZR-1 #792
Old Apr 27, 2026 | 05:17 AM
mazdaverx7's Avatar
mazdaverx7
I have new door panel carpet to install on the door panels on my 88. They came in on Saturday but this weekend was just too busy and I was unable to get to them. Some other parts came in, but I won't install them until I have the rest that I'm waiting on. It makes sense just to do everything at once.
Old Apr 27, 2026 | 07:29 AM
powerplaytwo's Avatar
powerplaytwo
RustyDuster,
There are two motors that control the mirror. One for vertical and one for lateral. They have jack screws that go into a worm drive gear which changes the rotation to linear motion. I had to buy a used mirror assembly and disassemble it to get the motor out to repair mine.
Old Apr 27, 2026 | 02:02 PM
RustyDuster
Originally Posted by powerplaytwo
RustyDuster,
Thanks power play, I actually put my power probe on both those motors and they worked. It's either wiring or switch. I got another (used) switch but still same thing. Of course there's a possibility the replacement switch has the same problem!
Old Apr 27, 2026 | 07:42 PM
Rogue One's Avatar
Rogue One
I have a complete set of Super Pro bushings I'd like to have installed. But the cost...yeesh...
Old Apr 28, 2026 | 10:21 AM
camburgaler's Avatar
camburgaler
5th Gear
Need to figure out how to get inside my passenger door panels without being able to open the darned thing. The latch inside is stuck locked.
Old Apr 28, 2026 | 11:34 AM
powerplaytwo
The mirror comes off by tilting it so you can get your fingers behind it and then pull on it gently and you will hear a popping noise which is the mirror coming off the jacking stud screws. Once the mirror is off you will see how it all works. The motors reverse direction by changing the polarity to the motors. As the motors turn you will see the jack posts going in and out. Apply your power probe to the wires for each motor and see it they move. I had to replace one as I said above.
The switches are an open frame that moves a contact back and forth to change the polarity. Once you get in there it becomes pretty simple operation.
Old Apr 28, 2026 | 12:22 PM
IHBD's Avatar
IHBD
Pro Mechanic
"What is the next thing to do on my list?"
  • All 6 U-joints. I'll replace the rear pads at the same time, as I have them on the shelf and will have the wheels off.
  • Ohm the plug wires. (It drops a cyl under acceleration. The injectors passed my tests. The wires are 2 years old, shouldn't be a problem, but checking costs nothing.)
Next trip is 5,500 miles RT. I leave June 1. I've got 4-1/2 weeks.
Old Apr 28, 2026 | 12:36 PM
Steve Swan's Avatar
Steve Swan
1994 LT1 1996 LT4
Thanks for posting this. 5,500 miles is a significant distance. I intend a similar distance this fall which i started a thread about. In the past, you've mentioned bringing a spare water pump and Opti. What other parts do you bring? If you will, I'd appreciate seeing a picture of tools you bring with your trips. What do you bring for fluids?
Old Apr 28, 2026 | 01:22 PM
QC2PE's Avatar
QC2PE
List of things to do on my C4 - Have the parts...need the time:
- Install distributor cover (was missing when I bought the car earlier this month...bought a new cover and screws)
- Install Door Panel Defroster Bezels (driver door is broken, passenger door is missing)
- Install Android Auto radio and bezel and verify speakers/wires
- Replace gauge cluster lighting (got the LED replacements from Batee.com)
- Replace all cabin screws (a lot of them are rusty for some reason)
- Replace lights in sunvisors (for some reason, the right light is missing on both sun visors...)
- Replace cracked gear selector glass
List of things to do on my C4 - Don't have the parts yet...and also need the time:
- Check clicking sound in dashboard (left side of steering wheel)
- Replace ALL weather stripping
- Replace steering wheel (leather is all cracked on current one)
- Replace all cabin lighting with LED (ordered pack from Amazon...never delivered)
- Replace latch cables for convertible top (snapped one of the cables while trying to tighten...both have broken plastic parts on them)
- Replace center console cover/arm rest (ordered from Zip, came broken, waiting to hear back from them...)
- Replace broken door trim on driver side
- Replace convertible top rear latch bezels with metal ones (plastic ones are broken and partly missing)
- Replace inside door lock **** on both doors
- Install small hood struts (one is missing, the other is likely dead)
- Install front bumper license plate filler if I can find one for a decent price
List of things I have done in my C4 so far (acquired on April 4, 2026):
- Replaced under hood lights with LEDs and cleaned protective glasses
Old Apr 28, 2026 | 02:54 PM
81c3's Avatar
81c3
Plenum pull and general check & clean of all the components under there on my LT-5
To Was the next thing on your to do C4 list
Old Apr 28, 2026 | 03:06 PM
ramahon's Avatar
ramahon
  1. Remove the strut arms and install the super pro bushings.
  2. Return and/or replace the front tie rods. Just installed moogs last month but neither boot seals
  3. Get a professional alignment
  4. Chase down some door and dash rattles
Old Apr 28, 2026 | 03:58 PM
Whaleman's Avatar
Whaleman
If you want to use my u-joint tool PM me your address. Dan
Old Apr 28, 2026 | 07:57 PM
CRUZNC4's Avatar
CRUZNC4
Transmission fluid/filter.
