HPDE Aftermath: Coolant and Oil Explosion
Unfortunately, on the last turn of the last lap of the last session, the car erupted in this thick white smoke. I pulled over immediately to see that the thing was gushing coolant and spraying oil around the engine bay. The organizers were telling me I was actually spewing oil out of the back of the car too (they said 15 bags of oil dry were used to clean that all up). This is where some of my confusion begins.
In my shock and disappointment at my beloved C4 having its first real breakdown in my care, I was absolutely terrified something really serious went wrong, like somehow a head gasket. I was confused initially as the car showed no indications of anything going wrong other than the white smoke. It was happily pulling north of 90 MPH in 5th gear before the white cloud showed up, and the half second it idled when I came to a stop did not sound any different. Regardless, oil in the tailpipe sounded like a huge issue, especially with the oil coming out at the same time as the radiator hose bursting. I have to move in a month, and I'm not the most skilled mechanic, so I was afraid this disaster might spell the end of my time with it. The hose connecting the water pump to the tee blew out, shown below:
However, I got the car back this morning after having it towed up from Millville, and I took a closer look at where the oil was coming from, and I discovered that this connector between the breather pipe and the throttle body had split around the bottom, which was why I did not see this immediately:
Does anyone have any advice on how best to proceed here? I don't think anything very serious happened, but I want to know for sure that I'm addressing root causes and not just symptoms. My initial thoughts are that I should replace this hose on the PCV breather and all the radiator hoses, then see if it will start and run, and go from there. I have some fear that the optispark got soaked from the coolant hose blowing out, but that seems like something I'll best be able to assess if I can start the car again. The coolant coming out was orange rather than the green of ethylene glycol antifreeze, so does that mean I should refill with dexcool? Any advice on getting this thing fixed up and back out on the road would greatly be appreciated.
Were your temperatures running fine beforehand?
I'd do just as you said, replace hoses, refill with dexcool, repair the line, change the oil out and make sure theres no coolant in it
I checked the dipstick right after the incident and again today two days after, and the oil there is full and remarkably clean. I'll get that oil changed ASAP so I can look more closely at the oil that's in there.
in 2005 the radiator hose blew out on my 93 while racing at nelson ledges as i went into a turn
i spun out (but stayed on the track) as the slippery antifreeze got all over my tire contact patch.
I think you are on the right track as far as your next steps in bringing her back to life.
When you have it all back together and try to start it will tell you a lot about what it needs next, if anything.
Good luck and keep us informed as you go.
Depending on where you live and the likelihood of the car encountering freezing conditions, consider using pure water with an anti-corrosion additive for coolant for HPDE days. If something happens again, the track crew will appreciate the foresite.
When you change all the hoses also change the thermostat. The LT1 thermostat has a little spring-loaded disc on it that closes off the bypass circuit to allow full-flow circulation through the radiator. BUT. At high-ish RPM the water pump is capable of producing cooling system pressures that can be harmful to the plastic tank radiator. (And hoses?) At high RPM the disc is pushed off its seat, bypassing some of the flow and reducing the pressure at the radiator. The hose that blew is subject to the highest pressure. The thermostat bypass valve may be sticky or acting up. Replace the thermostat.
For the opti all you can do is get it running and begin driving it again. If it runs for a few drive cycles with no problems, you probably won't have trouble. When I suffered a coolant explosion similar to yours, it was on my hoist while working on the car. I grabbed the water hose and douched the coolant off of my nice clean NCRS-prepped engine bay. I didn't even think of the opti. But it got douched and died a few drive cycles later. Your 94 has the opti vent system. If any condensation formed internally the vent system should extract it over time, but you have to get it running for the vent system to operate.
Sounds like you had fun. My parting thought is "How old are the flexible brake hoses on your car?" If they are the originals, I'd think about replacing those too before the next track day. Cheers.
For any LT1 owners that track their cars, can you run the Lt1 on track at redline or just below for almost a full 20min session? On my LT5 i cannot do that. The result is exactly what you experienced.
On the LT5 i had to remove the tstat and jimmy rig the bypass valve to force the coolant through the (upgraded aluminum) radiator with upgraded silicone hoses.
Does this need to be done on the LT1?
