Howdy, folks. I recently bought a C4 with an aftermarket NRG quick-release steering wheel. Naturally, these aftermarket steering wheels don't have airbags. I don't plan to take this car onto the track or anything, it's just going to be a cruising car. Frankly, I'd just feel better about driving a car with 1 airbag than 0 airbags. As such, I was thinking that I'd buy an OEM steering wheel and install that instead. I have several questions about this.
Has anyone here tried to do anything similar?
Is it even really worth it?
Would the previous owner have had to remove or otherwise render inoperable any of the wiring under the steering wheel when installing the NRG base?
If I were to try and source an OEM steering wheel and airbag module, how could I get one that's not too expensive?
Would an OEM airbag module still be reliable at this point, 33 years later?
I'm also wondering if it's a fool's errand to try to make safe a sports car that's older than I am...
EDIT: Alright, it seems like the very prospect of trusting a >30yr old airbag is unsound. Looks like I'm sticking with the NRG quick-release. Thanks for the replies, folks!
Reason: Thread resolution
Here's my opinion. I have a 1996, and the OEM Steering Wheel is THE MOST HIDEOUS wheel Chevy ever put on a car. It's ugly, bulky and there really is no good driving position. HAVING SAID THAT...Airbags were new at the time. They hadn't yet perfected them or gotten them to scrunch into a small space, so I'm sure this was probably the best Chevy could come up with at the time. I don't fault them, I just hate the wheel.
Yes, I know it's costly, but it's a damn nice looking wheel that uses the stock airbag. If you want to go stock, you can pick up a used wheel in good shape on fleaBay for $100-150. I've seen pre-owned airbags for anywhere between $75 and $150, Now, aside from a big bolt in the middle, I know nothing about the electronics involved. I would think they would still be in the column (hopefully not cut out). Maybe someone can chime in.
> $1050
> Still requires me to source a 30+ year old airbag
I appreciate the suggestion, really. Given the options, it seems like the best move is just to stick with what I've got and be extra careful so that I don't need the airbag.
I have an NRG wheel in my 92. I just stuffed the connector inside as I recall. You could certainly swap back, but it will likely be cost prohibitive. Irbags are not cheap, and cheap airbags are not trustworthy.
Honestly, I wouldn't really worry about an airbag if I had a 1993 or before model. I'd go out and get a nice Momo wheel or even better, head over to eBay and find an original Fittipaldi wheel. They're about $350. I loved mine back in the day. So yeah you might be better off.
