C6 Parts for Sale/Wanted C6 Corvette Performance Parts, OEM, Aftermarket, Superchargers, Turbo Kits, Wheels & Tires, Exterior Enhancements
Sponsored by: C7 Carbon
FS: Crank turning wrench for C6
Old Apr 29, 2026 | 11:52 PM
xBoostx's Avatar
xBoostx
Default Crank Turning Wrench for 27mm ARP Crank Bolt
These may well be the only wrench available for these purpose it works and yes it gets in there with the rack and pinion in place, it worked great for me to set the valve lash on my solid roller cam $75.00 picked up or plus the ride. 305$457$3066 David.
Old May 5, 2026 | 12:31 PM
xBoostx's Avatar
xBoostx
Solid roller cam motors need valve adjustments this tool will make your life way easier
xBoostx's Avatar
xBoostx
Still Available
Old May 18, 2026 | 10:06 PM
xBoostx's Avatar
xBoostx
To the top
Old May 19, 2026 | 05:35 AM
Ahrmike's Avatar
Ahrmike
You should note its for the ARP bolt, yes?
If I didn't buy a 12 pt wrench and cut the end off already, I'd be all over this. looks like it has better angle and leverage than my modded one.
Old May 19, 2026 | 08:22 AM
xBoostx's Avatar
xBoostx
Hey gent yes it is for the 27mm ARP Crank snout bolt
Old May 26, 2026 | 11:50 PM
xBoostx's Avatar
xBoostx
To the top
To Crank turning wrench for C6
