Intermittent Power Steering Loss On Track
Old Apr 30, 2026 | 07:34 AM
schaumi's Avatar
schaumi
Default Intermittent Power Steering Loss On Track
‘01 Z06, 112k miles. Periodic track car since 2021. Last fall I lost PS in a turn on track on Saturday. Later that day and next day everything was fine. PS pump would whine coming off the track.
This year I flushed 2 quarts of fresh fluid. Old fluid was dark and burnt. Flushed by disconnecting return line from reservoir and turning the wheels lock to lock with the car off.
Took it to the track this past weekend and had no whining, but did lose PS a few times. It was always after about 4 laps in the same turn. It would alternate sessions of working and going out. Just no Power Assistance.
No leaks, reservoir is full. Never does it on the street.
Thoughts on causes? Trapped air? Bad pump? Bad seal in rack? Something else?
Thanks!
Old Apr 30, 2026 | 07:36 AM
lucky131969's Avatar
lucky131969
Originally Posted by schaumi
‘01 Z06, 112k miles. Periodic track car since 2021. Last fall I lost PS in a turn on track on Saturday. Later that day and next day everything was fine. PS pump would squeal coming off the track.
Took it to the track this past weekend and had no squealing, but did lose PS a few times. It was always after about 4 laps in the same turn. It would alternate sessions of working and going out. Just no Power Assistance.
Thanks!
https://www.corvetteforum.com/forums...roadracing-23/
Old Apr 30, 2026 | 07:39 AM
schaumi's Avatar
schaumi
I’m asking a technical question about my car, not a question about driving it on the track.
The track part is just where it shows up. I may ask over there but thought I’d start here.
Old Apr 30, 2026 | 07:50 AM
lucky131969
Right, and you experienced a problem that is reproducible only in a track environment, and most likely many C5 Auto-xers have seen before...which lead them to making changes to their systems.
Old Apr 30, 2026 | 03:25 PM
G_Loc's Avatar
G_Loc
What fluid are you using? Still running the factory cooler?
Old Apr 30, 2026 | 04:58 PM
Ltngdrvr's Avatar
Ltngdrvr
Bad steering sensor?
On my car I get the traction control and active handling fault lights sometimes and the steering gets heavy, then it will go away and steering goes back to normal.
I'm figuring the steering sensor is the issue.
Old May 1, 2026 | 12:28 AM
Lowend's Avatar
Lowend
I'm betting you are overheating the PS fluid. It could be the factory PS cooler needs to be cleaned (easy) or just replaced with a more HD unit
https://turnonesteering.com/product/...nd-cooler-kit/
https://www.gspeed.com/products/gspe...eee-1777609641
Old May 2, 2026 | 07:13 AM
schaumi's Avatar
schaumi
Thanks all. I recently flushed it with Lucas PS fluid. That cured the whining when hot but perhaps I’ve done permanent damage to the pump. I’d driven it on track dozens of times without this issue before it started but maybe that was just luck. I’ll clean off the factory cooler for what that’s worth. Perhaps a new Turn One pump is in my future. I have a bigger radiator to put in so might be a good time to do both.
Old May 6, 2026 | 04:48 PM
imma_stocker's Avatar
imma_stocker
I bet you're boiling PS fluid on track. Bigger PS pulley and/or UD crank pulley will alleviate some of that along with upgraded PS cooler. Factory PS pump provide surprising excess of flow and pressure... enough to power a hydroboost on top of PS at all rpm.
Old Yesterday | 11:31 PM
Zpeedstr's Avatar
Zpeedstr
Default Over rev = over heat
I replaced the internal gerotor with a 50% smaller unit. Over heat problem solved. PS still works at low speed
The PS pump is designed to work at idle, and over reving at track rpm, which causes over heating.
Old Today | 09:26 AM
KOZ's Avatar
KOZ
Look at all those correct answers and the solution.
And not a single post of - Pull the codes!
Old Today | 09:39 AM
G_Loc's Avatar
G_Loc
Interesting. Where did you source it? How difficult was the job?
To Intermittent Power Steering Loss On Track
