63 and 64,65 intake
Old Apr 30, 2026 | 01:25 PM
Mitch03Z06's Avatar
Mitch03Z06
Default 63 and 64,65 intake
Can someone tell me what the differences are between the 63 340 hp manifold, and the 64 365 hp manifold?
Old Apr 30, 2026 | 02:18 PM
3030cam's Avatar
3030cam
The '63 used a Carter AFB while the '64 - '65 used a Holley. Not sure if there are other differences.
Old Apr 30, 2026 | 02:22 PM
JIMNAN's Avatar
JIMNAN
St. Jude Donor '25
63 340 is aluminum designed for the AFB type carburetor. 3794129 is the casing number.
64-65 is aluminum designed for the Holley type carburetor. 3844461 is the casting number. 365 HP in 64-65 and 350 HP in 65.
Old Apr 30, 2026 | 02:53 PM
Mitch03Z06's Avatar
Mitch03Z06
Thank you all
Old Apr 30, 2026 | 03:09 PM
Mitch03Z06's Avatar
Mitch03Z06
How is PCV valve routed on the 64 365 hp?
Old Apr 30, 2026 | 04:40 PM
lucky131969's Avatar
lucky131969
So you want to install a PCV valve instead of the controlled fitting on the carb?
Old Apr 30, 2026 | 04:42 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
on the side of the carb is a a fitting with what I recall to be a .035 orifice that restricts the vacuum to the oil fill tube
Old May 1, 2026 | 11:33 AM
Mitch03Z06's Avatar
Mitch03Z06
Maybe I should explain what I am trying to do. I have a 63 convertible without the original block. It has the correct casting number, and approximate date code, but it’s a T block not an F block. When I purchased the car it had a quadrajet, and a random Chevy cast iron manifold. The paper work I got with the car shows the engine was rebuilt to the 340 HP specs that the car was built with. Since I was 19 I have always wanted a 327/365 hp c2. I currently have an aftermarket 600 CFM Holley clone ( will get a 2818 when I have the $), 64 aluminum intake, and 64 air cleaner. I am looking for diagrams, pictures etc. showing how the crankcase is vented. I have also added a 67 dual master cylinder and power brake booster. So I need the fittings to connect the booster. I hope I may this clear. Thanks in advance, Mitch
Old May 1, 2026 | 11:39 AM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
The crankcase is vented through the large tube at the front of the intake. AKA breather tube.
327 /365 had solid lifters and a pretty healthy cam.
Old May 1, 2026 | 12:09 PM
Nowhere Man
Any 327 block is the same My dad has a service dated 2818 he would be willing to sell
Old May 1, 2026 | 05:09 PM
Mitch03Z06's Avatar
Mitch03Z06
Is there another block vent that goes from the back of the block to a connection on the air cleaner?
Old May 1, 2026 | 06:22 PM
Nowhere Man
yes just like any 283 or 327
Old May 3, 2026 | 06:31 PM
Nowhere Man
@Mitch03Z06 your PM box is full
To 63 and 64,65 intake
