clutch slave cylinder
Old Yesterday | 02:37 PM
ajsc4's Avatar
ajsc4
Default clutch slave cylinder
96 Lt4 6-speed. Replacing the clutch slave cylinder. There is a solenoid right behind the cylinder that is in the way. Can that be removed from the trans to facilitate in the removal. I don't want to remove it if there is something inside the trans that will fall into the inside and really mess me up! Anyone done this before?
Old Today | 06:35 AM
powerplaytwo's Avatar
powerplaytwo
Yes, it can be removed and replaced with a plug. It is for the “skip shift” that GM provided. I think you might need the plug in kit which is a resistor so the computer thinks it is still there. The light on the dash will still light up when it thinks you should skip the gears but it won’t keep you from shifting normally.
