Sponsored by: Wheel Design
Remote key problem
Old Apr 30, 2026 | 04:51 PM
KD21vette's Avatar
KD21vette
2nd Gear
Default Remote key problem
For my 2021 Stingray I used the remote to start the car many times. It will not start the car now. I changed the battery in the key and the door locks worked before and now. The frunk I have to try several times but starting does not work. Any suggestions?
Old Apr 30, 2026 | 05:07 PM
Ltngdrvr's Avatar
Ltngdrvr
Check engine light on?
Usually, if there is a code present the remote start won't work.
Old Apr 30, 2026 | 05:09 PM
Jimmers467's Avatar
Jimmers467
I'm sure you have already done this but just to be sure.... you did lock the doors with the remote before hitting the remote start and the remote lock worksd, right?
Old Apr 30, 2026 | 11:41 PM
Bob Paris's Avatar
Bob Paris
I think that feature is free for a limited time and you may have to add an OnStar plan that includes it. My remote start on my '22 hasn't worked in years.
Old May 1, 2026 | 12:03 AM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
Bob,
I have the OnStar Remote Access plan on my 2022, so I can't weigh in on your statement. However, this is the first time I've ever heard that you need an OnStar plan for the key fob remote start button to work. Anyone else out there who can confirm this?
Old May 1, 2026 | 05:18 AM
ahalachis's Avatar
ahalachis
If it is low on fuel it wont remote start, or as already said if there is a CEL it wont remote start either...
Old May 1, 2026 | 06:07 AM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
Have you tried the second FOB?
Old May 1, 2026 | 07:49 AM
NewOldFart's Avatar
NewOldFart
Car battery is fully charged?
Old May 1, 2026 | 07:54 AM
Andybump's Avatar
Andybump
Bob, I think he is talking about the fob, not the remote start from the phone which does require OnStar.
Old May 1, 2026 | 08:03 AM
Andybump's Avatar
Andybump
Your manual lists some conditions that may disable it. Check them if you have not already. Also, with the frunk (and the remote start too, actually), you have to push the respective button twice. I assume you are already doing that.
To Remote key problem
