C8 ERay/GSX/ZR1X ERay/GSX/ZR1X Discussion
Sponsored by: Vibe Motorsports
12v Lithium Battery replacement
Old Today | 07:30 AM
24E-Rayyy's Avatar
24E-Rayyy
Navigator
Default 12v Lithium Battery replacement
Hello was wondering if anyone has had to replace their 12v lithium battery?
my e-ray has been dead stuck in my garage for over 3 months now finally had technicians come and take a look but they say need to replace battery.
have been waiting for a few weeks for battery but no timeline or much advise from gm care.
Just wondering how long others have had to wait for battery?
Old Today | 07:43 AM
24/Eray's Avatar
24/Eray
Dupe
Old Today | 07:44 AM
24/Eray's Avatar
24/Eray
Nonsense.
Why was your car not put on dollies, moved out of the garage and at the dealer? Any competent tow driver can do this.
Where do you live?
Any competent tech can pull the cover and hook a jumppack up to the terminals on the battery itself and get the 12v battery out of uvp.
I can.
Old Today | 08:03 AM
24E-Rayyy's Avatar
24E-Rayyy
Navigator
8 different tow trucks the roadside assistance sent over none would take it out.
I would think putting on dollies would be easy but they all say not enough room and dont want to be held responsible.
Technicians that came over could not get power to battery with the jumppack. I have also got the Noco boost pro and have had no luck.
Old Today | 08:11 AM
LT5 John's Avatar
LT5 John
Active Streak: 90 Days
You have no room to jack up the car on each side of your garage? If so use a scissor jack to jack up each tire and put the wheel Dollie’s under each wheel. Get 4 guys one on each corner of the car. Once the Dollie’s are in place guide the car out.
Old Today | 08:29 AM
24E-Rayyy's Avatar
24E-Rayyy
Navigator
Yeah I should just go and buy the scissor jacks and dollies myself because the roadside assistance has been useless.
But my issue will still be waiting for the 12v battery as the dealership is not trained on these vehicles and would just replace rather then waking up battery from UVP mode.
Old Today | 08:35 AM
LT5 John's Avatar
LT5 John
‘Call other dealers in the area to see if they have a certified tech.
Old Today | 08:48 AM
jafo1970's Avatar
jafo1970
Where do you live?
Old Today | 09:00 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Hmm, my C8 Certified tech is great BUT no question when he certified no E-Rays. Plus no GM 12 volt Li-Ion info in Owner's Manual or in the several page GM Tech Link (October 2024) re the E-Ray 12 volt Li-Ion battery did not cover.
My Guess, you might be able to disconnect the Li-Ion battery from the 300 volt EV battery via converter in the power system using the Green discounted (see my Pic below) and it might start and run long enough to get out of the garage.
Per the GM Tech Link must disconnect the Li-Ion battery from the 300 volt EV battery via a converter in the power system using this Green plug BEFORE you disconnect the battery negative terminal. Putting it to OFF makes the car rear wheel drive only. IMO worth trying to see if after disconnecting another battery or even Jump Box connected to the battery terminals starts the car!
Old Today | 09:03 AM
24E-Rayyy's Avatar
24E-Rayyy
Navigator
The local dealership sent over two certified technicians and a battety replacement was their suggestion at $2000 but have not been given a timeline for battery to arrive after 2 weeks.
I live in Ontario just outside GTA
Old Today | 09:20 AM
Ltngdrvr's Avatar
Ltngdrvr
This is not under warranty?
Old Today | 09:33 AM
24E-Rayyy's Avatar
24E-Rayyy
Navigator
Dealership has said not covered under warranty. I do have a case open with GM Care and have been waiting on them to hear back for over a week about warranty coverage.
Old Today | 12:37 PM
Ltngdrvr's Avatar
Ltngdrvr
Well, if it does turn out to not be covered, then I would not even take it to the dealer, I'd buy an aftermarket battery to replace the original, probably save you a lot of money.
But, I can't imagine it not being covered, car isn't 3 years old yet, unless warranty is different in Canada.
Old Today | 12:46 PM
JerryU's Avatar
JerryU
Hmm, I have an early E-Ray at the local dealer February 2024. It was part of the 1st 100 on GM's QC Hold which they do for new models. All released at the same time.The only made sooner were GM Exec Cars driver to check for issues. They were sold with a restricted warranty, as always.
Old Today | 12:55 PM
gatorfl's Avatar
gatorfl
ouch.. Why haul the car around. just take out the battery yourself, take to GM for testing, if they wont replace it then get a better version that has the emergency backup thats easy to activate. It does seem silly that the stock ones do that but doesn't seem there is a way to easily unlock it.
Old Today | 02:21 PM
24E-Rayyy's Avatar
24E-Rayyy
Navigator
If I take the battery out myself they would void warranty.
I did speak with someone else today from GM Care that reached out to me and they suggest waiting on dealership to order new battery and that this was the first case of an e-ray needing a new 12v lithium battery.
To 12v Lithium Battery replacement
