Sponsored by: Innova
View Poll Results: Which amp
Kta 450 bridged 100 Per channel
50.00%
Mono amp 350 x1
50.00%
Voters: 2. You may not vote on this poll
Sub Amp choice for C6 vert
Old May 2, 2026 | 11:50 AM
Superspirit's Avatar
Superspirit
Default Sub Amp choice for C6 vert
Okay, I have a Kenwood nav unit, Jl audio C2 3.5's for the upper doors, infinity tweets for dash corners, C2 5.25 separates for behind the seat. Also have alpine Kta 450 50 wattsx4 to drive the speakers. I've also purchased RF R2D2 10" subs to put in the doors. With sounds good block off plates to enclose the doors. Now to the question. I have an extra KTA 450 that I can bridge to 100 watts per channel for the 2 10's rated for 100-200 rms in the doors. Want opinions on if that's enough amp or if I need to go to a large mono amp for the subs?
Let me know what your thoughts are and why. I don't want to lose any space in the car as we want to travel in it next year when the wife retires.
also not looking for car shaking bass, just good quality rounded out sound for 8 hour a day drives. Thanks to all who respond.
Old May 7, 2026 | 10:21 PM
FAUEE's Avatar
FAUEE
100W to those speakers in the doors is more than enough to rattle the hell out of the doors, block off plates or not.
Expect to spend a lot of time on dampener and foam on those door panels.
Old May 8, 2026 | 10:18 AM
Superspirit
Thank you for that reply. I realize I'll have to do a lot of sound deadening in the doors. Part of the plan is to deaden the doors.
Old May 8, 2026 | 09:02 PM
Superspirit
Okay, it turns out that my alpine 4ch amp doesn't have a low pass filter and can't be used for subs.
so that makes the deciding simple. 350 watt mono sub amp ordered. So split between the 2 r2sd2-10 subs that will send 175 watts to each. Thanks to those that participated.
Old Yesterday | 06:40 PM
Superspirit
Guess I'm in this thread by myself. Anyway sub mono amp has arrived, tried to mount subs but they interfere with the windows. Waiting on sounds good adapter plates to space them out.
Old Today | 08:24 AM
FAUEE's Avatar
FAUEE
I commend you for trying to "make it work". I'm not wired that way, lol. I would be not worrying about the LPs at all because I'd run them active via a DSP (you're almost certainly going to want a HPF and a LPF for them to reduce resonance and rattles).
That said, those are deep subs at over 4.5". They're also very low Qts for this application at 0.47, for a free air use case like a door you ideally want around 0.707 Qts, as you have no box airspace to influence the Qtc..they also don't play particularly high only hitting 250Hz, or deep only hitting 45 Hz. They are not ideal for this use case.
I'll be interested to watch your updates while I plan my stereo endlessly lol.
Old Today | 08:55 AM
Superspirit
Alpine amp has the hpf's and now the subs have the lpf through the sub amp. Now waiting on speaker adapters to space the subwoofers out as they interfere with the window.
the Kenwood I installed has the DSP built into it. But crutchfield tech recommended a seperate lpf for safety reasons to protect subs and amps.
To Sub Amp choice for C6 vert
