C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Radiator guards
Old May 2, 2026 | 06:54 PM
Ryder2020's Avatar
Ryder2020
Default Radiator guards
What radiator guards should I buy???? I know chevy pushes the scrape armor but what else is out there that you all like and does the front need to come off with all of them?
Old May 2, 2026 | 08:20 PM
DVC8's Avatar
DVC8
I had my dealer install the Scrape Armor version as I didn't want to remove the bumper as I'm sure I would have damaged something! I would guess there might be a brand that can be installed without removing the front bumper but I wouldn't want something that requires 30 or so zip ties holding it together! I did install the Scrape Armour side grilles myself and that was pretty straight forward following Paragon's installation video. Maybe others can suggest a brand that installs on the front without bumper removal.
Old May 2, 2026 | 08:57 PM
DeltaT's Avatar
DeltaT
CF Community Team
I installed the Radiator Grill Screens race version in the front and sides, both with the metal type as opposed to (IIRC) ABS. The fronts can be installed without bumper removal and took me about 3 hrs. total including removing a bunch of undertray bolts. Not a hard job if you are patient and read the instructions well. I believe the fronts had a total of 4-6 mini-zipties which are extremely hard to detect after installation as they blend in with the Carbon Flash trim quite well.
Old May 3, 2026 | 08:29 AM
Viperr's Avatar
Viperr
6th Gear
I installed the Radiator Grill Screens that DeltaT installed in the front and sides with the metal type also.. The fronts took about 3.5 hours to install without bumper removal and without using a lift. Takes almost as much time removing and installing the the undertray bolts and panels than installing the screens. Fairly simple and easy job. Their Installation Video is excellent. Follow the instruction and watch the Video.The side grills had two tie wraps each and you can not see them after the install. The fronts have a total of 4-8 tie wraps each side which are installed as per the instructions are very difficult to hard to detect after installation as they blend in nicely with the Carbon Flash Grills. The RGS grill screens are of high quality and a lot less expensive than the competition and you do not have to remove any body parts.
Old May 3, 2026 | 08:54 AM
La Z06 Dude's Avatar
La Z06 Dude
I ordered mine as a GM accessory when I ordered my car. They are supplied by Scrape Armor, so you can order direct from them if you already own the car. They look great and I am very happy with them! My dealer tried to install them when the car was delivered but they had no clue how to install them, so be careful about that. So, I had to hire a trusted Exotics shop in my area to remove the bumper and reinstall them correctly. Since the parts are a GM accessory, I wish the factory would just install them when you order a car to be built. I am not sure why they don't offer that.
Old May 3, 2026 | 08:55 AM
La Z06 Dude
By the way, the install on the Z06 is much more involved than the stingray.
Old May 3, 2026 | 09:42 AM
AzDave47's Avatar
AzDave47
^^^^ This. The Z06 has radiators in the middle of the front grill, the Stingray does not.
A friend bought a Z06 off the lot from a Valley dealer, who installed the Scrape Armor guards w/o removing the front bumper - 3 times. after that they took the front bumper off to install it properly. My friend only paid for the initial install.
Old May 3, 2026 | 10:15 AM
Kenny94945's Avatar
Kenny94945
Ya, on a SR the bumper does not have to be removed, on a Z06 ya, bumper bmp needs to be removed.
Scrape Armour fit is fantastic, both form and function.
However, if you wish to do the side/ quarter panel vent guard, SA does not make a set for a SR.
In that regard, other co-members may offer some guidance.
FWIW these guards will be a long-term modification, whether saving some hundreds up front is prudent,
I don't know Also as to any warranty claim using a non-GM approved grille, again IDK
Good luck with your decision.
Old May 3, 2026 | 12:09 PM
DVC8's Avatar
DVC8
Either version you install I believe these protective screens are a must to have and I wouldn't drive the car without them.
Old May 3, 2026 | 12:10 PM
DeltaT's Avatar
DeltaT
CF Community Team
A consideration if you don't put them in when new: the cars at Ron Fellows Corvette Driving School do not have radiator screens and had a lot of rock strike marks on their radiators, considering they sell them at ~10K miles.
Old May 3, 2026 | 05:16 PM
saleentim's Avatar
saleentim
Mine came with Scrape from GM up front and I added Radiator Grill Shop for sides as they were a whole lot cheaper.. Worth the big savings for sure. If it didn't come from GM up front, I would've just done the cheaper option of RGS.
Old May 3, 2026 | 05:53 PM
lgodom's Avatar
lgodom
Just installed Scrape Armor front guards a couple weeks ago. I paid a C8 tech to install them at his home. Already installed the side guards installed after they were introduced over a year ago.
Definitely need them since the radiator fins had damage from bug and rock impacts. Expensive but well designed and worth it.
Old May 3, 2026 | 06:12 PM
MSGZ06's Avatar
MSGZ06
Good to know and will be purchasing the RGS product to install myself.
Old May 3, 2026 | 06:57 PM
mavzy's Avatar
mavzy
For those that are paying to get the guards installed (especially the Scrape Armor ones), how much are you being charged? I've gotten several quotes for ~800 from independents
Old May 3, 2026 | 07:52 PM
lgodom's Avatar
lgodom
The dealer should be less than $800. I paid $300 to a C8 tech who works on the side. I was planning on doing it myself when I purchased them.
Old May 3, 2026 | 08:30 PM
VinnyP's Avatar
VinnyP
I installed Scrape Armors front and sides on my 25 Z06. No big deal to remove the bumper cover. I would suggest having 2 people to help line it up to put it back on. The side screens are very simple to install.
Old May 4, 2026 | 03:17 PM
CliffB-99's Avatar
CliffB-99
Buy them from the official GM Accessories website, pick your favorite dealer for delivery and select the dealer installed option. The dealer has to install it for the GM approved cost. Install is $250 under “Ship to seller and install option”.
To Radiator guards
Old May 4, 2026 | 04:03 PM
AzDave47's Avatar
AzDave47
^^^ '' and the OEM way of installing them it to take off the front fascia for the C8Z.
Old May 30, 2026 | 03:28 PM
B/Stock's Avatar
B/Stock
It can be done without removing the front bumper. Ask your Dentist if you can have a dental pic/waxing instrument, its a bit tedious but can be done. I went with Radiator grill store, have to zip tie but they look great, can't see the zip ties unless you really look for them.
Old May 31, 2026 | 04:22 AM
JSZ060526's Avatar
JSZ060526
4th Gear
I ordered the Scrape Armor guards yesterday, but I’ve been second‑guessing whether the front set is really necessary. My other car is a 2023 Acura TLX Advance, and it has a pretty large opening beneath the grille where the radiator and fins are fully exposed. I don’t run grille guards on the TLX, and you can clearly see the marks from impacts (bugs, debris, etc.), which made me wonder why the grille guards are considered so important on the Z06.
I’m not trying to start a debate - I’m just trying to understand whether the guards are truly essential or more of a preventative accessory.
