[C2] Still have a slight shimmy in steering wheel ???
Old May 3, 2026 | 04:23 PM
riggsjr's Avatar
riggsjr
Default Still have a slight shimmy in steering wheel ???
I have new Diamond Back tires and CA 1965-1966 Corvette Direct Bolt-On Knock-Off Wheels fully balanced on my 66 coupe.
I still have a slight shimmy when I am cruising at 55-65 but when I push the clutch in the shimmy goes away. I do feel it in the steering wheel and the car. Could this be my driveshaft U joints?
What else should I check? Should I get a front and rear wheel alignment?
Old May 3, 2026 | 05:21 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
if you swap the tire and wheels from front to back, is it still there
Old May 3, 2026 | 05:50 PM
leif.anderson93's Avatar
leif.anderson93
While it's unlikely to be a wheel/tire issue if the vibration disappears when you push in the clutch, there is a slight possibility it could be a bent wheel. More likely, there is an issue with the drivetrain.
To confirm if it's the engine or the drivetrain, try this: While at highway speeds and experiencing the vibration, push the clutch in and briefly rev the engine to the RPM you were just driving at. If the vibration returns while coasting but revving, it’s an engine/flywheel issue. If it stays gone, it’s likely your U-joints on, either, the driveshaft or the half shafts.
Old May 3, 2026 | 10:11 PM
DansYellow66's Avatar
DansYellow66
You might check your rear transmission bushing and yoke for wear. Grab the u-joint of the yoke and try to move it up and down. If there is play in it, it can cause a vibration at speed that might feel like a shimmy in the suspension. There are tools for pulling and installing a new bushing without having to disassemble the transmission.
Old May 15, 2026 | 11:36 AM
riggsjr's Avatar
riggsjr
I did swap them and it helped!! Still I have a little.Maybe I am getting to picky driving a car that he 60 years old.
Thinking about doing an alignment on the car next.
Old May 15, 2026 | 02:17 PM
leif.anderson93
Did you do what was suggested in post #3? When you ask for assistance and it's given, common courtesy dictates a minimum of a response
Old May 15, 2026 | 04:54 PM
riggsjr's Avatar
riggsjr
I live in a congested area in NJ. Not to many places to bring it to that speed. As I was on the highway today I forgot to push it in and try that.I will next week and report back.
To Still have a slight shimmy in steering wheel ???
