OEM or Haltech ecu....learning to tune
OEM requires you to stop the engine and flash the ECU with updates, reboot and restart, log and start over etc.
An aftermarket ECU, if you buy the "right" one will allow you to make dynamic tune changes on the fly. Why is this any better you may ask?
Well, because if you are tuning for LBT or MBT (Best fuel or spark for max torque) then you will want/need to have realtime feedback and updating if you want to achieve anything in a reasonable amount of time.
You can hold the engine on a load bearing dyno at a set RPM and MAP load, vary spark and or fuel (separately) and dial in the best timing or fueling. Do that across the entire operating range of the engine and you will have a beast.
Realtime tuning is also great for dialing in large cams etc as you can get feedback immediately on changes, etc, etc.
You want one with good support, logging and interface etc.
