Spring - Don't Forget to Flush Brake Fluid!
Old May 5, 2026 | 03:04 AM
Pettrix's Avatar
Pettrix
Default Spring - Don't Forget to Flush Brake Fluid!
Doing a brake fluid flush on my 17k mile car but I believe the fluid to be OEM, so its 12 years old. Definitely needed to be changed...
Old May 5, 2026 | 05:35 AM
449er's Avatar
449er
CF Community Team
At 12 years old, I believe you are right!
Old May 5, 2026 | 07:32 AM
gsflyer2011's Avatar
gsflyer2011
It is already too late. Not changing it regularly will corrode your calipers due to moisture build up in the fluid, and pretty soon you are looking at seized calipers, which need to be rebuilt at substantial cost.
Old May 5, 2026 | 08:10 AM
gsflyer2011
I forgot to mention the ABS controller. After the fluid flush make sure you do 3-4 hard braking to activate and get that awful trapped fluid out of the pumps. That is even more expensive fix if it is rusted shut.
Old May 5, 2026 | 08:40 AM
BadAV's Avatar
BadAV
It's on my list, but I need to do the Charger and F-150 first. It's been about 5 years since I did them; used Valvoline synthetic DOT 4. They all still "look" very clean.
Old May 5, 2026 | 08:52 AM
449er's Avatar
449er
CF Community Team
Buy some brake moisture strips & check the moisture level of your fluid, Amazon sells them cheap
Old May 5, 2026 | 11:36 AM
Pettrix's Avatar
Pettrix
Brake fluid is the least maintained fluid in most cars, with power steering fluid coming in at #2.
I know plenty of people/vehicles that have 50,000 or 100,000+ miles on the original brake fluid.
Old May 5, 2026 | 01:11 PM
lilcuda's Avatar
lilcuda
Every two years for my GS!
Old May 9, 2026 | 05:40 AM
Pettrix's Avatar
Pettrix
Where can one find the bleeder valves for the GS calipers? There is one bleeder that I want to replace with a new one.
I assume the bleeders just thread out and the new ones just thread in. Then you just have to bleed that one caliper where it was replaced. Right?
Old May 9, 2026 | 09:22 AM
dr_gallup's Avatar
dr_gallup
I don't think they are anything special but as always Rockauto is my first place to check. Just have to bleed that caliper.
https://www.rockauto.com/en/catalog/...der+screw,1676
Old May 9, 2026 | 11:33 AM
EVRGRN's Avatar
EVRGRN
Good PSA and use of Motiv bleeder as pressure source, but definitely don't let your fluid go that long.
Old May 9, 2026 | 04:07 PM
kanvasman's Avatar
kanvasman
And don't let the fluid get on the paint.
Old May 9, 2026 | 05:57 PM
Pettrix's Avatar
Pettrix
Sadly, RockAuto wont ship to this state. They have a lawsuit going on.
AcDelco looks decent. Some of the aftermarket bleeders supposedly leak (per reviews)
Old Yesterday | 06:00 AM
Pettrix's Avatar
Pettrix
I assume the new bleeder is just installed "dry" with no type of thread sealant needed, right?
Old Yesterday | 10:31 AM
Corvette_Dez's Avatar
Corvette_Dez
My truck hasn't had a brake fluid change in over 25 years. Calipers aren't seized. No leaks (rusted steal lines). No brake system issues at all.
Old Yesterday | 02:57 PM
Pettrix's Avatar
Pettrix
​​​​​​Brake fluid is one of those things that goes unnoticed, but once it goes bad , that's when it really goes bad with leaking caliper piston seals, leaking lines leaking, hose fittings, diminished braking, etc.
Most people don't notice the slow and gradual brake pedal feel loss as the fluid goes bad over the years. I just changed the fluid in an older car and afterwards, it almost feels like I did a complete brake job on it. Brakes smoother, less pedal push, and no pulling to a side, just from a fluid change.
If you ever tracked a Corvette with old brake fluid, specially 20+ year old fluid, you would crash the car after the brake system failed due to brake fluid failure. Ron Fellows racing school changes the brake fluid on all the new C8s on a regular basis. Otherwise, people can crash, get injured, or killed
Old Yesterday | 03:18 PM
Corvette_Dez
I apologize, sometimes I forget to indicate hyperbole.
My truck has air brakes. No fluid, no calipers.
The Corvettes are all on pretty strict maintenence schedules. The drivers based on milage, the not based on time.
To Spring - Don't Forget to Flush Brake Fluid!
Old Yesterday | 03:28 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Change all your fluids if you have no recent record. Best maintenance you can do!
Old Today | 03:15 AM
Pettrix's Avatar
Pettrix
The AC Delco bleeders are not easy to find. Tried a few online sources and they are not available.
Will keep looking...
Old Today | 08:53 AM
FAUEE's Avatar
FAUEE
I did this. Accidentally of course but yeah, I did it when I bought my 92 track car. Seller said brake fluid was fresh, it was not. I should have checked it.
Obviously, I didn't die. And I didn't crash. I navigated it off track and into the grass while avoiding other cars. If you can't handle an emergency situation like that, you have no business being on track, or frankly on the road.
Don't take this to mean "ignore your brake fluid and send it". I'm not saying that. I'm saying it's not as dangerous as telling your wife you'd like to bone her sister or best friend cuz she's prettier, and she put should be able to handle it as a driver (and you shouldn't do track days places that are all walled off as a novice).
