What year did the Frunk on the Corvette Go to the auto close. I have a 2025 z06. And mine doesn't auto close. You have to push it down, like all of the past years.
You may have to use the button on the bumper to open it, let it pop up and wait for the beep prior to pulling it open. After that the auto close should work again.
I can drop mine from a couple of feet and it will pull down automatically. If you leave it open for a while before shutting it, you have to push the open button on the fob or under the bumper to wake it up again. The rear hat hatch will close automatically all the time when pressed downward. The front latch is finicky.
C4 of Year Winner (performance mods) 2019
Originally Posted by Ryder2020
my 25 closes like the older models.
Your 25 has soft-close, my 24 Z06 and my 25 E-Ray had it. It's probably the one thing I miss on my 23 70th Z06. If your 25 isn't working, take it to the dealer to have it checked.
I just looked, even my window sticker says I should have it.
I leave the frunk slightly open while the trickle charger is connected for several days between drives. Would always have to re-open the frunk before attempting a soft-close, like the car wouldn't remember that frunk was open for that long.
MY 2024, so 2-years now been doing it that way.
Today, I did the same cycle, but frunk soft close would not engage, even after several re-opens. I had to force it to close the whole way. Rear soft close is reliable like said above.
On both my 24 & 25, if the frunk is left open over about 10 minutes, you had to unlock it again (either with the fob or under bumper button) for the soft close to work.
