shock leak
Old May 6, 2026 | 06:06 PM
natekg's Avatar
natekg
Cruising
Default shock leak
mechanic advised of a leaking front left shock. does this look concerning? if so who soon should I get it replaced? also could this cause the squealing im getting despite replacing my front pads and rotors with powerstops. thanks
Old May 7, 2026 | 10:48 AM
MissileDoc's Avatar
MissileDoc
This shock leak document should be helpful.
File Type: pdf
Old May 7, 2026 | 04:11 PM
lilcuda's Avatar
lilcuda
I recommend wiping them down and checking again after a few weeks of driving. But at a quick glance, the wetness on the boot looks concerning. Does the car drive OK?
Old May 7, 2026 | 04:29 PM
natekg's Avatar
natekg
Cruising
only thing I can think of are vibrations that feel like its traveling from the front of the car to the rear during high speeds
Old May 7, 2026 | 04:39 PM
Pettrix's Avatar
Pettrix
I believe its FINE. Wipe it down and check 500 miles later. These are mag ride shocks and will seep fluid, which is normal and they can last 50,000 miles with that slight seepage.
Shock would NOT cause a squealing but control arm bushings can cause a squeak when moving.
Old May 7, 2026 | 07:58 PM
gsflyer2011's Avatar
gsflyer2011
This.
Old Today | 06:46 PM
schizcat's Avatar
schizcat
More details would be great. Year, mileage, etc. Shocks are fairly cheap. Replace them.
To shock leak
