'15-'18 Owners Get your A8 Flushed!
Old May 6, 2026 | 06:13 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Default '15-'18 Owners Get your A8 Flushed!
I wanted to share a quick update for anyone on the fence about the A8 Triple Flush.
I have a 2016 C7 with 43k miles and no record of the service being performed by the previous owner. I decided to have my local dealer handle it last week, and I can tell you with 100% honesty: the difference is absolutely night and day with the new fluid and filter. The shift quality and overall smoothness are significantly improved.
If you haven’t had the TSB triple flush completed yet, I highly recommend getting it done regardless of your mileage. At this point, the factory fluid in these early cars is nearly 8 to 10 years old. It’s well worth the peace of mind and the drivability gains. Even if you have a 2014 with the A6, I am sure you can benefit from a fluid flush.
Old May 7, 2026 | 11:40 AM
kodpkd's Avatar
kodpkd
AND, if you purchased the car used, you don't have any idea what someone put in your car. I have the 2014 A6 and changed all the fluids. Just check the latest GM updates for all the fluids, things have changed since your manual was printed.
Old May 7, 2026 | 12:30 PM
C7Z16GS's Avatar
C7Z16GS
1st Gear
Default '15-'18 Owners get your A8 flushed
I am new to the C7 forum but not not new to the Corvetteforum. I am here from the C6 Z06 forum. I bought a 2017 Grand Sport 2LT with 5000 miles on it. I was experiencing tachometer variations while driving in the 40-80mph range. I had the triple flush done at a local dealership and it totally changed the way the car drives. It is a night and day difference. I have put about 2000 miles on the car since having the triple flush done and everything seems to be working the way it was designed.
Old May 7, 2026 | 12:33 PM
Haven’t had the transmission fluid flushed on my 2014. Guess I need to consider it even with just 10K miles on it.
Old May 8, 2026 | 09:52 AM
MY04CE's Avatar
MY04CE
Vetteman - With a 2014, A6, you do not need to worry about the A8's shudder and the triple flush, but, given the age of your Vette, suggest you have the trans flushed (in fact, all fluids should be flushed due to age instead of just mileage unless you already did it). Good luck.
Old May 8, 2026 | 11:23 AM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
Good rule of thumb, I would change every fluid in any car, regardless of mileage no later than 5 years max.
Old May 8, 2026 | 12:44 PM
Landru's Avatar
Landru
Providing not too many miles (IIRC Chev recommends every 50K), a flush probably a good move.
On a related topic, we own a CTS w/ what I believe either A8 or very similar to C7.
We'd awful shuddering, took it to our long standing wrench.
Good guy w/ >30 yrs experience w/ all vehicles.
Asked for a flush.
He cautioned against FF due to our high miles, >100K
Advised full flush MAY lossen debris trapped in every nook and cranny.
Crap could clog tiny passages causing real headaches down the road.
Instead he drained every drop of fluid he could, refilled w/ 'new' fluid as recommended by GM for A8.
Has been nearly flawless ever since.
High miles the deciding factor behind his strategy, FWIW.
YMMV
Old May 9, 2026 | 01:40 AM
geewez's Avatar
geewez
I believe it was the A8 transmissions that will give you problems not the earlier A6 transmissions.
Old May 9, 2026 | 12:10 PM
Landru's Avatar
Landru
Correct., A6's were darned near bullet proof, my first 2 sure were.
Replaced by the 'improved' A8.
Old May 9, 2026 | 06:55 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
Slight correction to your title - triple flush needs to be done on any 2019 build before February 2019.
Old May 10, 2026 | 12:06 PM
Photomania's Avatar
Photomania
Does that mean you average driving about 833 miles annually?
Old May 10, 2026 | 12:38 PM
TxLefty's Avatar
TxLefty
As nearly as I can tell the A8 is a good transmission, it just doesn't like the junk fluid that GM put in it.
Old May 10, 2026 | 02:17 PM
aklim's Avatar
aklim
For an A6, I'd just change the fluid. For any A8, unless it is for certain made after 19, I'd do the triple flush. If you wait till symptoms appear, some damage might be done if you catch it in time. If not, the good news is that the new transmission should not need a triple flush if the right fluid is put in at the time of installation.
Old May 10, 2026 | 02:20 PM
aklim's Avatar
aklim
Asked for a flush.
YMMV
Yep. My old 700R4 failed even after a transmission pan drop for exactly that same reason, I have been told. Only thing is that I changed fluid as a "Hail Mary" to buy me some more time. That old, well intentioned warning never dies. All he did was a single pan drop. Question you need to ask is this. If you report ANY issue with the transmission, the TSB pays for a flush as long as your car is under warranty. If GM could have gotten by with a pan drop, don't you think they would have told the tech to do that instead of a triple flush or triple pan drop?
Old May 10, 2026 | 03:26 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
IIRC, the triple flush need to be done if the transmission was built before that date, there is a tag on the tranny showing the tranny build date.
It's possible that the car was assembled after the changeover date but the tranny was built a few days before that and has has the old ugly fluid.
Old May 10, 2026 | 03:27 PM
Gearhead Jim
St. Jude Donor '13
It's possible that the car was assembled after the changeover date but the tranny itself was built a few days before that and has has the old ugly fluid.
Old May 10, 2026 | 09:46 PM
aklim's Avatar
aklim
They might have been by 2014 but were they when the first came out? According to THIS, there were some issues.
To '15-'18 Owners Get your A8 Flushed!
Old May 10, 2026 | 09:54 PM
aklim's Avatar
aklim
IIRC, it was the "hand me down" stuff that was the issue. Had they used the right stuff to begin with, maybe there would be less problems? That said, if I knew then what I knew then what I know now, well, I'd be rich beyond the dreams of avarice. Like most things, you know now what you should have done and when you started, there were tons of issues that got ironed out over time.
Old Yesterday | 11:05 AM
Landru's Avatar
Landru
No doubt A6 had issues following introduction.
However as stated mine worked well from the get-go.
Lucky?
A8 following the 'partial' fluid change on our CTS, has performed well.
No shudddering, a decent xmission w/ buttery smooth shifts.
Still took GM fo' evah to come up w/ improved fluid solution vs replacing entire unit those first few years.
Torqued-off a good many owners, rightfully so IMO.
An expensive lesson for the general, somewhat akin to C8's DCT problems.
Old Yesterday | 11:44 AM
aklim's Avatar
aklim
Lucky?
My point is that you may have been lucky but either way, new inventions always come with some risk as opposed to a system that has had all the bugs worked out of it. A 700R4 built today is going to be better than when it first came out. That's the risk we have to be willing to take with new inventions. It would be best if they had been able to spend a decade field testing it with road driven cars to make sure it works before offering it for sale but I don't know if that's reality.
