Sponsored by: Wheel Design
Adding PPF but contemplating ceramic
Old May 7, 2026 | 09:24 AM
REDCON1's Avatar
REDCON1
Default Adding PPF but contemplating ceramic
Recieved my Eray last week and will be scheduling PPF installation (front bumper, headlights, and hood) next week. But I'm somewhat contemplating adding ceramic coating to the rest of the car. Yeah, I know I should do it. But she will live in the garage a majority of the time. I had my other car (Integra) ceramic coated and it does make bug removal easier as this is my daily driver. I ordered Ethos Resist to put on my truck as an extra coating and may try it on the Eray. So, my Eray will be driven on a limited basis. Should I go ahead and get it ceramic coated while their adding PPF?
Old May 7, 2026 | 09:30 AM
chevyrules727's Avatar
chevyrules727
2024 C8 of the Year Winner - Unmodified
Ease of cleaning makes it worth it, especially if you want to use a blower to dry the car.
Old May 7, 2026 | 09:59 AM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
This. With a good professionally done 2-stage ceramic, I can use a blower to dry my car completely dry and never touch it with a towel. And it helps a good bit with keeping bugs from sticking, most of them come off with my pressure washer, to the point that if it's only slightly dirty I can usually skip using the wash mitt altogether. So it's both a tie saver and it cuts down on the amount of tower/mitt to paint contact, which even with microfiber products, do contribute to swirls.
Old May 7, 2026 | 11:01 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Yes do a ceramic coating on entire C8, I did 100% PPF and then had entire ERay coated so easy to clean.
Old May 7, 2026 | 11:31 AM
chevyrules727
Forgot to mention...... Ceramic coating will make it easier to clean the PPF.
My Model 3 is ceramic coated, my moms Model Y isn't.
Getting the dirt off he PPF on the side rockers on the 3 is easy. Getting the dirt off the PPF on the side rockers on the Y is a PITA.
Old May 7, 2026 | 12:15 PM
ensignlee's Avatar
ensignlee
In for a penny, in for a pound.
I would rather do ceramic and no PPF thaPPfo PPF and no ceramic coat.
But best is both. And ceramic coat is the cheaper od the two anyway.
Old May 7, 2026 | 05:06 PM
REDCON1's Avatar
REDCON1
the PPF quote they gave me was $1250 (750 for bumper/headlights and 500 for hood). Plus 7yr ceramic was $1350. I think the ceramic coating is Ion brand??
Old May 8, 2026 | 08:26 AM
ahalachis's Avatar
ahalachis
OP, if you are asking/contemplating because of the cost of the ceramic coating, then that is really a decision you need to make. If you are asking because you are wondering about the benefits of ceramic coating, then I think you will find most folks would tell you that when done properly the benefits out weight the cost. Keep in mind that it is just not ceramic protective coating that gets applied, there is a paint decontamination and correction process that takes place prior to applying the ceramic coating that when coupled with ceramic coating brings out the depth and color of your paint, it is a notable difference...
Old May 8, 2026 | 08:28 AM
Smokinlmm's Avatar
Smokinlmm
Ceramic pro and PPF for the win…
Old May 8, 2026 | 09:44 AM
REDCON1's Avatar
REDCON1
All good points! But I have a question, is paint decontamination/correction on a vehicle that is truly less than one month old needed? Perhaps I'm foolish but I just presumed the factory paint process was flawless.
Old May 8, 2026 | 09:50 AM
DonC7's Avatar
DonC7
Factory paint is never flawless. Paint correction, then ppf, then ceramic is the way to go. It’s a $100,000.00 car. Why hold back on protecting it.
Old May 8, 2026 | 11:34 AM
FFIN90's Avatar
FFIN90
From: ================ From Toronto ================ 9/11/01 FDNY 343 R.I.P.
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
I picked my 2026 up at the dealer and drove it straight to the detail shop, about a 10 min drive. Had full PPF and ceramic done, they did a thorough inspection on the paint and highlighted the imperfections and sent me photos before starting the job.
Old May 8, 2026 | 11:35 AM
REDCON1's Avatar
REDCON1
I agree with you on protecting it. But it's costing a good bit of money to protect it besides PPF/Ceramic. I.E. front/rear splash guards, side radiator guards, front radiator guards. But since they will already have my car for PPF application, I guess it would be senseless to not get ceramic as the same time.
Old May 8, 2026 | 11:42 AM
REDCON1's Avatar
REDCON1
When I called and questioned them about PPF process, they said there would be visible "seams" on the lower section of the front bumper. There are two vertical painted pieces on the lower front bumper. I'm not exactly sure where they are talking about but I do know I'd prefer to not see any seams where they joined two pieces together. From what I've read, any exposed PPF edge will capture dirt and become highly visible.
Old May 8, 2026 | 12:33 PM
JRYELLOWCORVETTE's Avatar
JRYELLOWCORVETTE
PPF the front and lower side then ceramic coat everything. Not cheap abut worth it.
Old May 8, 2026 | 01:42 PM
flittlejr's Avatar
flittlejr
Default Water Spots
Had openly mirrors forward and ceramic in November. Never driven in rain always garage till Saturday. Got home late Saturday so foam power washer and leaf blower dry. I noticed today that the part that has ppe and ceramic has little spots like while parked outside water must have dryed and causing water spots. Tried Chem Guys waterless. No good. Tried 303 no good. Any ideas Black 2025 Z06.
Old May 8, 2026 | 02:43 PM
ensignlee's Avatar
ensignlee
Woah what?! That's crazy.
My prices were $5.5k for full body PPF and $700 for the ceramic coating.
Your shop is both undercharging for PPF and way overcharging for ceramic lol. I see facebook ads bombarding me with ceramic coating prices for $500 all the time.
To Adding PPF but contemplating ceramic
Old May 8, 2026 | 03:00 PM
Swolejack's Avatar
Swolejack
I have a 2024 Coupe. I had the entire car wrapped with PPF before I picked it up at
MacMulkin then a couple of days after picking it up I brought it to Automotive Elegance for
MA legal window tint and full ceramic over the PPF. The car looked like it was glowing when I
picked it up. Did a ceramic boost last year and it really enhanced the shine and made it so
much easier to wash/dry. Entire car just got refreshed again and it's really hard for the water
to stay on the car when I'm washing it and wheels do not accumulate any brake dust.
Quick once over with the leaf blower and the car is good to go!
Old May 8, 2026 | 04:12 PM
Ramets's Avatar
Ramets
Just my 2 cents. But I'm looking at ceramic infused PPF, instead of having to do both procedures separately. I'll be having it done next week.
Old May 8, 2026 | 08:50 PM
Jimmers467's Avatar
Jimmers467
I had track PPF package applied as well as a ceramic coating to the entire car. The ceramic coating was totally worth it. Not only does it make it easier to clean but it makes the color pop because of the paint decontamination and correction that is done as part of the process. The car looks amazing. I'm happy that I did both. I think you'd be happier with the ceramic coating on top of the PPF as well.
