Would car even run if fuel pump polarity was reversed?
Old May 8, 2026 | 10:48 AM
dizwiz24's Avatar
dizwiz24
Default Would car even run if fuel pump polarity was reversed?
RXP340 pump burnt out the intake bulkhead connector (Due to higher amps).
I replaced this with Racetronix BCWA-C44 which has higher rated terminals.
***However. Here is where the confusion lies.
It states that if using an RXP340 pump that the polarity needs reversed. It doesnt give any diagrams or further discussion on how to do so.
I imagine I could pull one of the weatherpack connectors out at the harness outside the tank if I had to..
I figure when I go to start this thing up, hopefully it will either run (if its polarity is correct), or not run (if wrong).
What I dont want to have happen is it runs half-arsed or 'runs' but is not 'right'.
I imagine if the fuel pump ran the wrong way it would try to pull full thru the return pipe.....
So whats CF's verdict on whether the car would 'run' with the polarity reversed ?
(I would call racetronix technical support but as many of you know its useless. They dont reply to emails and maybe 1 / 100 times somebody will pick up the phone. )
Old May 8, 2026 | 12:56 PM
jv9999's Avatar
jv9999
No, it would spin backwards being a DC motor. It would not work.
Old May 8, 2026 | 02:41 PM
dizwiz24's Avatar
dizwiz24
Originally Posted by jv9999
No, it would spins backwards being a DC motor.
would the car run with it spinning backwards
Old May 8, 2026 | 02:48 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
are you serious?
2011KLR's Avatar
2011KLR
All other things equal, if the pump is pushing fuel pressure to the rail the car will run.
Reversing polarity on the pump itself will make it run backwards BUT - the pump you have is aftermarket - maybe it is simply wired to where the connector is just backwards to the stock one.
Old May 8, 2026 | 04:03 PM
dizwiz24's Avatar
dizwiz24
Originally Posted by Cruisinfanatic
are you serious?
its not a dead head system. Its a loop with feed and return lines.
the return pipe which could in theory become the feed pipe if it sucked fuel due to reverse motor direction
Old May 8, 2026 | 04:04 PM
mrlmd's Avatar
mrlmd
Before installing it in the fuel tank, why don't you just put it in a bucket of something and energize it with 12V and see if it pumps. If not, reverse the polarity and try it again. You'll figure it out and see for yourself.
Old May 9, 2026 | 12:15 AM
RustyDuster's Avatar
RustyDuster
What about the fuel pressure regulator though? When I replaced mine I examined the design and it did not seem that it would run in reverse.
Old May 9, 2026 | 09:35 AM
dizwiz24's Avatar
dizwiz24
very possible
there may also be a check valve in the rxp340 fuel pump also (unless it overpressurizes and bypasses it
somehow)
i started the car up and it ran, so hopefully i got it right
Old Yesterday | 01:54 PM
Raidmagic's Avatar
Raidmagic
By my personal experience it will not run wired backwards. I wasted 1/2 day checking everything else because I was sure I wired it right. Turned out I didn't. If I would have double checked myself I could have saved some time.
To Would car even run if fuel pump polarity was reversed?
