Valve Adjust After Cam Break In?
Old May 8, 2026 | 04:22 PM
AKjeff's Avatar
AKjeff
Default Valve Adjust After Cam Break In?
I have 230 miles on my newly rebuilt 327 w. Flowtek heads, Howards hydraulic flat tappet cam/lifters and Comp roller tip rockers.
I thought I had a valve train noise after the initial 20 minute break in run so I ran the valves again.
I later found the cause of the noise, it wasn't the valves.
I took the car to town a few days ago and knew something wasn't right under the valve covers.
I got home and pulled the plugs, they all look great, rolled it over and checked the valves and five were loose.
I've set them again.
Fearing bad lifters or cam lobes I tried checking valve lift, but with the lifters bleeding off I'm not getting consistent readings.
Is there a way to check valve lift with hydraulic lifters?
I dislike these rockers, my socket gets wedged in the narrow end of the rocker when the valves are closed and throws off zero lash.
I have to make a slight adjustment, remove the socket and check the feel.
I was warned off of these a while back but forgot about that when I was shopping for rockers for this build.
I came and searched through my saved threads here and see that if a lobe or lifters go bad it's usually much sooner than 200+ miles after cam break in.
I will probably put it back together and test drive it, any damage that's been done is already done.
Last edited by AKjeff; May 8, 2026 at 11:49 PM. Reason: correction to brand of rocker
Old May 8, 2026 | 05:49 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
To check lift. Remove rocker arm and indicate right off the top of the pushrod.
Your nuts could have backed off? Or you could have wiped a few lobes.
It is a worry.
Old May 8, 2026 | 07:35 PM
blue427's Avatar
blue427
if you haven't done any damage,readjust all the valves and use posi-locks.they won't loosen up like the stock nuts.
Old May 8, 2026 | 09:30 PM
AKjeff's Avatar
AKjeff
It is a worry.
Removing the rockers so the valve springs won't compress the lifters makes sense, thanks.
I've wondered if the nuts are loosening (I wouldn't have thought lock nuts would), I'm going to measure the length of the studs sticking up above the nut, if it happens again I should know what the problem is.
@blue427 It didn't occur to me to install posi-locks, they'd certainly be easier to adjust. Once I'm sure the cam/lifters are good I'll do that.
Old May 8, 2026 | 10:53 PM
4-vettes's Avatar
4-vettes
Yes if you reused lock nuts they can come loose. I know of a few guys that have learned this lesson.
Old May 8, 2026 | 11:54 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I had my BB rebuilt during Covid but not back on the street until a couple summers after. I kept getting returning ticks so kept adjusting the valves - sounded great for a while then ticks returned. Turned out the Comp Cam intake pushrods were soft and the tips were wearing down under the rockers. Of the 8 intakes, 6 were deformed — no issues with the exhaust rods.
Just something to look at.
Old May 9, 2026 | 08:06 AM
AKjeff's Avatar
AKjeff
Thanks, I'm picking up a set of polylocks today, I'll check the pushrods and measure the cam lobe lift while I have the rockers loose.
I'm using Trick Flow pushrods, I think I selected them on length and availability, I don't know how the quality compares.
Old May 9, 2026 | 08:47 AM
ctmccloskey's Avatar
ctmccloskey
I would also suggest that you verify that your push rod's are open inside and clear. I rebuilt my 427 and within an hour it started tapping lightly and it was getting progressively louder as I drove it.
After taking it home and found the blocked pushrod had kept my #6 exhaust valve from getting lubricated and the roller rocker arm was destroyed as it was black and overheated. After replacing the push rod and the rocker arm all was well again.
The oil passageway inside the push rod is small so be sure to verify that each one is clear before using them. If the rocker arms are not getting enough oil then they will get noisy and be damaged.
Best Regards,
Chris
Old May 9, 2026 | 10:44 AM
Rebelyell's Avatar
Rebelyell
Vast majority of friction/heat in all rocker arms are in TRUNNION --- NOT in tip! Prima facie evidence: Look at any LS series motors' much improved rocker arms.
Unless your Howards cam has well Over 0.310" LOBE Lift, Suggest revert to plain stamped-steel, OE-replacement-type rocker arms.
Old Yesterday | 11:12 AM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
I completely dislike the Comp Cam Rollertip rockers.
They solve a problem which does not exist, and completely miss the main issue of heat and friction at the trunion or ball socket.
Just use stock rocker arms.
Old rockers are worn together and paired with their pivot ***** and must NOT be mixed up.
OTOH the stock crimp nut arrangement has been one of the SBC weaknesses since the beginning of time.
They do significantly wear out and get loose if adjusted a few times, and then they will back-off while driving.
This was always a significant challenge on solid lifter cars and was the only reason you had to adjust the valves basically every weekend.
There was a torque spec on these things when new. You could put new ones on and they would still loosen because the threads of the stud also wear.
If you tested a bunch for torque, you could eventually get a set that would hold, for a little while.
Almost all of the poly-locks were too tall and would not fit under the factory valve covers. Since they are made for stud girdles. So new valve covers are required.
Aluminum rocker arms were also too fat and would not fit under stock valve covers.
Arrrggghhh!!!
A viscous circle.
I sold all this stuff in the speed shop for 25 years, and none of it helped the power of a street engine.
None of this stuff was really needed on 90% of the guys that bought it all.
Just use GM rocker arms, with SHORT poly-locks made by Crower, that WILL fit under factory valve covers.
Your valve lash will hardly ever change again. I revved my solid lifter LT-1 to 6800 often (racing & autocross) and the lashed stayed the same for many years straight.
I checked it sometimes, but it never changed.
Eventually I just waited for the sewing machine purr to change, and that took years....
And my OEM aluminum valve covers fit and hid it all.
If you have a really aggressive high lift cam, or a BB with same, then stainless rocker arms are might be a worthwhile upgrade, over factory ones. They are smaller in size then the aluminum ones and fit under valve covers better. That is what I run on my .600 lift solid roller cam BBC, with factory valve covers. With the mandantory short Crower Poly-Loks. But the short ones are still tight fit on a BB.
That is all the valve cover clearance I have, about .100
That is all the valve cover clearance I have, about .100" Above the nut, that is the tight spot, even with the short poly-loks.
Old Yesterday | 11:57 AM
AKjeff's Avatar
AKjeff
Thanks Leigh. I don't remember why I ended up with these rockers, I assembled the engine two years ago and finally had time to drop it in.
I picked up a set of ARP Poly-Loks, they do fit under the chrome covers that I'm currently using.
I like the idea of checking the clearance, I'll get out the playdough.
The cam is a .485/.498 lift and I've spun the engine to 5500 a few times.
I'd never had problems with the stock Chevy rockers or nuts before, but most of my prior experience was with stock 283's in old pickups, with no tach.
Old Yesterday | 01:40 PM
AKjeff's Avatar
AKjeff
And I now find a better selection of stamped steel rockers on the Summit website, all I had to do was leave out the max. valve spring diameter and more parts popped up.
This engine is a (somewhat) disposable place holder while I get my 383 built.
If these current rockers act up I'll trash them and buy a set of stamped steel rockers.
Old Yesterday | 02:42 PM
Rebelyell's Avatar
Rebelyell
Suggest don't limit your choices to summit.
JME: Elgin "Black Ice" (cryogenic-treated) stamped steel RA's. IIRC, all black ice have longer slots.
OE GM RA's are very good as well.
To Valve Adjust After Cam Break In?
