Sponsored by: Wheel Design
Neutral problem
Old Yesterday | 04:33 PM
Rocketmanwpb's Avatar
Rocketmanwpb
Default Neutral problem
I have recently started experiencing a problem when I activate Neutral by holding both paddles in. After a while the car will let the clutches go and engage first gear. The car will then not allow me to reengage the clutch release. Anybody experiencing this issue?
Old Yesterday | 07:39 PM
Andybump's Avatar
Andybump
No.
How long is "a while"?
What are the other conditions? Foot on brake? Are you on a hill?
How do you know the clutch has reengaged? Does the car start to creep forward?
Old Yesterday | 10:58 PM
1Coop61gt's Avatar
1Coop61gt
Why would you hold it in neutral like that with the paddles ? And if you really want it in neutral that bad why not use the button on the console. Its dedicated to only that. Certainly hope you have your foot on the brake while you doing this .
Old Yesterday | 11:20 PM
Zymurgy's Avatar
Zymurgy
Moderator
I have never experienced that. In fact, once you engage neutral by pulling both paddles, you can keep neutral engaged by just holding one of the paddles.
Old Today | 09:51 AM
2021Vettelover$$'s Avatar
2021Vettelover$$
I have done that but when you drop to one it will go into gear.
Old Today | 09:55 AM
2021Vettelover$$
It goes into gear but not right away.I should have mentioned that
Old Today | 10:26 AM
RKCRLR's Avatar
RKCRLR
I'm trying to understand the problem. Pulling both paddles doesn't put the transmission in Neutral, it is like pushing the clutch pedal in a manual transmission car. The computer will still downshift through the gears as you come to a stop, they just won't be engaged.
Are you saying that if you let off the brake pedal with the paddles pulled when stopped and give it some gas that the car will start moving forward?
Old Today | 12:29 PM
2021Vettelover$$
Very simple the transmission reengages if only one paddle is pulled instead of both.No one is saying it selects neutral just releasing the clutches.
Old Today | 12:57 PM
Zymurgy's Avatar
Zymurgy
Moderator
Not on my 2020 it doesn't. Perhaps they changed this behavior at some point. After getting the clutches to disengage by pulling both paddles, I can let one go (either one) and just holding the one paddle will keep the clutches disengaged
Old Today | 01:05 PM
Andybump's Avatar
Andybump
I think his question was to the OP though. Who is saying that when he keeps both paddles pulled "for a while" the clutch re-engages. The owners manual says nothing about re-engaging the clutch as long as both paddles are held. And furthermore, it also says the clutch will remain dis-engaged as long as either one of the paddles is pulled - "The vehicle will remain in this condition until both the + paddle and − paddle are released. " After a double paddle declutch, you must release both paddles before the clutch engages according to the manual.
And this the way it seems to work for most of us.
Both conditions described....that it will re-emgage the clutch while both are pulled, or re-engage as long as one is pulled after both have been pulled, are not how it is described in the manual.
Old Today | 02:53 PM
Rocketmanwpb
Read your comments. I'm old school and when I come to a stop I pull the paddles to disengage the transmission. If I'm stopped for an extended time I place the car in neutral. I know that once both paddles are pulled you only need to hold one paddle back to keep the clutches disengaged. I thought that I might have been releasing the paddle but I have come to the realization that has not been happening. When the clutches reengage, I am unable to get the clutches to disengage by pulling the paddles.
Part of my thinking is that the clutches are not fully disengaged when you come to a stop. GM has said that the clutches should last the life of the car. I had my 08 C6 for 16 years and 181,000 miles. I think what GM really means is that the clutches will last the life of the warranty period.
Interesting fact. One of the engineers in our club recently told me the reason the C8 has wet clutches is for temperature control of the clutches.
Old Today | 02:58 PM
Zymurgy's Avatar
Zymurgy
Moderator
Unless he is an engineer on the C8 Corvette or on the Tremec DCT (or similar qualifications), I'd not put any weight behind that comment.
To Neutral problem
