Rough idle at cold start
Old May 8, 2026 | 08:57 PM
Marshall0429's Avatar
Marshall0429
Cruising
Default Rough idle at cold start
2002 C5 stock coupe with 104,000 miles and suddenly developed a rough idle when cold and definite engine miss or stumble. Smooths out after warmed up but after a 15 min highway drive at 75 mph and coming to a stop the engine shook then stopped and car ran fine. Looked but see no vacuum lines loose and plug wires all connected. No codes in dic either. Any suggestions on where to look would be appreciated.
Old May 9, 2026 | 12:00 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you don't have at least a code reader I'd take the car to a diagnostic shop...they test and don't guess...could be a skewed ECT sensor...if a misfire can be a few things..."looking" to see if you have a vacuum leak isn't of much help...you can look at your fuel trims... that will help you.
Old May 9, 2026 | 12:15 AM
the_merv's Avatar
the_merv
Check the Spark Plugs. I've had the same when a Plug goes bad.
Old Today | 12:40 AM
drtyTshrt's Avatar
drtyTshrt
To Rough idle at cold start
