C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Ac compressor doesn’t come on
Old May 9, 2026 | 09:06 AM
yzrider's Avatar
yzrider
Default Ac compressor doesn’t come on
Where to start?
turn defrost or set temp to low and compressor never engages?
any recommendations on steps to take.
thanks!
heat works and controls on hvac all work.
Old Yesterday | 11:20 AM
Drbobzr1's Avatar
Drbobzr1
2021 C4 of the Year - Modified Finalist
if you just replaced the orings, or recharged the system , disconnect the battery and reconnect it 5-10 minutes later...the ecm has to re-set......(sometimes helps to pray to the zr1 god).....Happened to me when I replaced the orings/recharged. Started up and A/c worked as it should...
Old Yesterday | 11:53 AM
yzrider's Avatar
yzrider
I haven’t done a thing yet. I’ll start with checking the charge then I guess: that’s a symptom of being low/empty?
Old Yesterday | 12:49 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Is the 1st ac light on the HVAC dash head unit flashing? if it is your low on Freon. You can get diagnostic help thru it.
Old Yesterday | 01:33 PM
Drbobzr1's Avatar
Drbobzr1
Steve....your video is so good...easy to understand and 1000's of time better then wild guessing.....appreciate it much...thanks bob
Old Yesterday | 03:49 PM
FASTAZU's Avatar
FASTAZU
St. Jude Donor '16
Thanks Rd Bob hope it helps someone!
To Ac compressor doesn’t come on
