C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
ported CNC LS7 heads vs aftermarket ported LS7 heads on a stock bottom end LS7
Old May 9, 2026 | 12:57 PM
WeaponsGradeTorque's Avatar
WeaponsGradeTorque
Default ported CNC LS7 heads vs aftermarket ported LS7 heads on a stock bottom end LS7
The power increase benefit is clearly seen on a larger displacement motors (>427) from aftermarket LS7 heads vs ported CNC LS7 heads from various testing sources such as Richard Holdener.
But I have yet to see a scientific apples to apples tests (i.e. same CR) comparing the power difference between these heads (CNC LS7 vs ported aftermarket) on a stock 427 LS7 bottom end. Has such back to back tests been performed?
Old May 9, 2026 | 02:44 PM
jb78L-82's Avatar
jb78L-82
Have you contacted some of the vendors such as AHP or Tony Mamo and inquired about their proprietary aftermarket LS7 heads for comparative data?
In my opinion, there are 2 issues when considering a ported OEM LS7 head or an aftermarket NEW LS7 replacement head:
1. Flow characteristics as you are pointing out in your question.
2. Head durability and reliability, correcting the inherent flaws and machining issues along with materials used in the OEM LS7 head versus various aftermarket NEW LS7 heads that do not have those issues, whether you are looking for max airflow or not. "Fixing" the OEM LS7 head may or may not be a permanent solution to the head issues, as has been discussed quite often on this forum.
Old May 9, 2026 | 09:32 PM
Tony @ Mamo Motorsports's Avatar
Supporting Vendor
Its just math and physics....
A stock LS7 head flows 365 ish on the intake thru a 270 cc port
A modified (ported) OEM LS7 head flows in the 390 range typically but the port is now even larger 285 - 290 cc's.....more flow but the efficiency (air speed) is similar
1.35 CFM per cc versus the same 1.35 CFM per cc in the ported head.....more volume of air (higher CFM ) will make more power though.
Now compare that to just my mid-priced Stg 2 version on my LS7 heads.....408 CFM thru a finished port volume thats only 265 cc's ......20 more CFM thru a 20 cc smaller hole than a ported OEM head
Think about the gains in airspeed that creates and air speed is just as important as air volume regarding performance gains.....1.53 CFM per CC a much larger number indicating the efficiency of the heads are far greater.
Its a clean sheet design that is just shaped better and has material added in the right places to keep flow moving in a laminar fashion at a higher rate of speed.....helps to pack the cylinder better for every combustion event
Math and physics.....flow dynamics 101
Porting factory castings will always limit your gains and the biggest issue is you didnt really cure all the geometry issues either.....the other huge perk a clean sheet design offers in an aftermarket casting
Call me and we can discuss this in more detail but I hope the simple math I just laid out above helps you to get a better grasp on the situation your comparing.
There is more to it but than just that but what I laid out covers the bulk of why a really efficient designed aftermarket casting will always outperform an OEM casting assuming the port, chambers, valve jobs etc is a really effective design.
Point is you can buy aftermarket castings that perform worse than stock also.....but with a clean sheet aftermarket head if you invest the time and truly design a better piece you have the potential to vastly improve the CFM per cc .....aka airspeed
The best performing cylinder heads always have both....alot of flow and alot of airspeed
-Tony
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
Old May 9, 2026 | 11:32 PM
WeaponsGradeTorque
Tony,
Thanks for taking the time to explain the advantages (from a physics stand point....the "cfm per CC" figure of merit) of your cylinder heads vs going with a stock CNC ported LS7. I've been researching the results from your heads, and one thing is for sure they make great power in all the results I have seen! Very impressive. I will be in touch.
-WGT
Old May 10, 2026 | 12:40 AM
Supporting Vendor
Tony,
-WGT
Love your screen name and love the fact you have been a member on this board as long as you have
Would appreciate the opportunity to help you out
Gimme a call....no pressure.....just want to further explain the benefits of running heads that are this efficient and go over a potential package with you (cam, heads, intake etc.)
The potential these cars have when modded correctly, even mild combos just absolutely rip
Cheers,
Tony
Old May 10, 2026 | 01:45 AM
Hib Halverson's Avatar
Hib Halverson
Pro Mechanic
Pro Mechanic
Originally Posted by Tony @ Mamo Motorsports
Love your screen name and love the fact you have been a member on this board as long as you have (snip)
Cheers,
Tony
Hey. come on Tony. I've been on the CF since 1999...27 years! How come I don't get any love? I even liked one of your posts here.
Oh, wait...
Ok, I get it. I don't have a cool screen name.
Old May 10, 2026 | 02:58 AM
Supporting Vendor
Oh, wait...
Hib,
Your a legend on this board....I would be curious who is still posting on this forum that has been on here longer than you!?!
But we have done business already and you already know where to go for all your cylinder head and induction needs 😜
(Plus he has a cooler screen name! )
Old May 10, 2026 | 09:25 AM
jb78L-82's Avatar
jb78L-82
Tony,
I am a newbie, Oct 2007!
Awaiting your ported TB for the C6Z06 I ordered, after memorial day, when Im back!
Jeff
Old May 10, 2026 | 10:02 AM
Kevin Mason's Avatar
Kevin Mason
I've only been here 26 years, and I am far from a gas flow specialist, but one thing Tony mentions that cannot be overstressed is the importance of port velocity.
Old May 10, 2026 | 10:20 AM
Costa T.'s Avatar
Costa T.
Y’all are all legends. I’ve been on CF since 2010 as a looker but joined only until I bought my first Vette
Old May 10, 2026 | 11:28 AM
Pacha's Z06 RF's Avatar
Pacha's Z06 RF
I have what I jokingly call Tony's stage 1.5 heads. I have the stage 1 heads with bowl blending and couldn't be happier with the results and peace of mind that my heads will not go nuclear on me.
Many thanks Tony 🍻
Old May 10, 2026 | 02:58 PM
jb78L-82's Avatar
jb78L-82
I have Tony Mamo designed AFR 180 64 CC heads when he was the cylinder head guru at AFR on my 78 C3 corvette Gen 1 355 and they are the best flowing, highest velocity aftermarket street cylinder head on the market for their size, even today. Throttle response and mid range torque are unreal............for a Gen 1 355 SBC.
Old May 10, 2026 | 06:11 PM
Supporting Vendor
Originally Posted by jb78L-82
Tony,
Jeff
Your in luck.....your getting one of the newer versions of that TB that we have been working on for quite some time.
Just finished a CNC program for that particular piece (LS7 bronze blade). Real happy how it came out.
Much like the CNC ported LT throttle bodies I started producing late last year the CNC work is super nice.....very small stepovers (only .010).....could pass for an OEM finish for sure
Takes longer on the CNC machine but the results look so good I dont care about the extra 15 mins it takes per part to have the finish that nice.
Im putting this one in a box today and mailing it to one of our customers....note the missing giant hunk of aluminum that's usually blocking a portion of the TB blade obstructing flow.
You have to know what one of these looks like stock to better appreciate the final shape!
Regards,
Tony
To ported CNC LS7 heads vs aftermarket ported LS7 heads on a stock bottom end LS7
