C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Frunk removed for track weight - car says trunk not closed now?
Old May 9, 2026 | 04:27 PM
DMS1970's Avatar
DMS1970
Default Frunk removed for track weight - car says trunk not closed now?
2025 stingray, I posted in tech as well, but figured I might find a answer here. Is there a way to make this work?
Old May 9, 2026 | 05:23 PM
BuckySti's Avatar
BuckySti
i’d have to wonder how much weight you’re saving versus the loss of aerodynamics.
Old May 9, 2026 | 09:14 PM
DMS1970's Avatar
DMS1970
Sorry, the frunk tub, not the hood
Old May 9, 2026 | 09:36 PM
RUQWIKR's Avatar
RUQWIKR
Do you still have the charging port / emergency exit button plugged in that is in the RF of the frunk area? I heard it causes issues if you leave it unplugged in.
Old Yesterday | 07:44 AM
mtraylor2001's Avatar
mtraylor2001
So what is weight savings of frunk tub delete? ~20lbs????
Old Yesterday | 03:01 PM
DMS1970's Avatar
DMS1970
Yeas, the frunk and trim can shave around 20lbs.
short answer is, without the frunk plugged in the car doesn’t function correctly and the antenna wire for keyless start is in the frunk as well. I put it back in and the car is fine.
Old Yesterday | 03:36 PM
patton's Avatar
patton
St. Jude Donor '09
too bad it didn't work out 20 pounds is a lot to shave off for racing , free horsepower
Old Yesterday | 09:44 PM
95vettski's Avatar
95vettski
Lithium battery will save you 25lbs no codes
To Frunk removed for track weight - car says trunk not closed now?
