Messed up my C2 again, Driveability)
Old May 9, 2026 | 04:52 PM
SledgeHammer 2.0's Avatar
SledgeHammer 2.0
Default Messed up my C2 again, Driveability)
Screwed up my car again.
Parked the car and somehow left the key on. Went back a couple of days later..Battery completely dead, put a fresh battery in the car, fires right up, Idles really well but bucks on take off, almost like the accelerator squirter isn't working (it is) runs rough going down the road. Figured I toasted the points leaving the key on so I got a new set of points and condenser , all they had was a uni set (AC Delco D1007), set the dwell to 30*, set the timing to 12 initial, 32 total, hooked up the vacuum advance,( it works, hooked to manifold vacuum port on carb), Car still bucks on take off and runs bad going down the road, tried a used coil off my Plymouth, didn't help. Voltage at coil with engine running is 10.5.
I am at a loss, what else could I have messed up? Anyway I could have messed up the cap or rotor leaving the key on?
Old May 9, 2026 | 06:22 PM
acstephenson's Avatar
acstephenson
This is a tough one but I can't see anything like this damaging the cap or rotor. What I can see is something like ignition switch contacts being overheated (though not likely) or the resistor being overheated or possibly the voltage regulator barely working now or the coil wire getting so hot (from the coil) that it barely conducts spark now because the carbon conductors have broken down or a poor connection between the switch and the coil. I suggest that you eliminate all the primary ignition causes at one whack (since you have replaced the points and condenser) by jumpering from +12v to the '+' terminal of the coil. If the problem persists, I would then rig a temporary wire from the points to the '-' terminal of the coil. You could probably run it through the window in the cap. If that fails then replace the coil wire or at least test it with an ohmmeter. That ought to be a good start. Final thought: Does this thing have an electric choke? You could have burned him up. If there is a radio suppression capacitor connected to the '+' side of the coil, you might try disconnecting him(just the lead) because he could have been damaged by the coil's heat.
Old May 9, 2026 | 06:52 PM
Tampa Jerry's Avatar
Tampa Jerry
You can for testing purposes, connect a wire from the positive side of the coil to the positive side of the battery, That will bypass the ignition switch and give full battery power to the ignition system. Jerry
Old May 9, 2026 | 07:37 PM
SledgeHammer 2.0
It has 10.5 volts running to the + side of the coil. I can hot hire it and see if that helps but I thought it was supposed to have around 6 volts running
Old May 9, 2026 | 08:06 PM
acstephenson
Somewhere between 7 & ~ 9 is typical but it varies. The important point is that it has nearly 12 VDC while cranking. The only reason that 12 volts isn't supplied all the time is that it will burn the points fairly quickly but for testing purposes that's fine. Your 10.5 volts is a bit high and suggests that the coil isn't pulling quite enough current. Get the jumper test out of the way and go from there. One thing that could cause the somewhat abnormal voltage is a broken wire between the distributor ground and the breaker plate. It might have burned up.
Old Yesterday | 06:40 PM
SledgeHammer 2.0
ok. So I did both jumper wires and none of that really helps.. Just for fun, I pulled the front float off and made sure the power valve was good and it wasn’t just flooding the engine.
One thing I did notice is that when I hooked the positive side of the coil wire to the coil it arcs pretty good. Never noticed that before. Is that normal? That was with the points closed, when they are open, it doesn't do that. I attached the video hopefully
File Type: mov
Last edited by SledgeHammer 2.0; Yesterday at 06:43 PM. Reason: Grammer, added content
Old Yesterday | 06:47 PM
Limp's Avatar
Limp
Years ago a mechanic at the shop struggled with the same symptons as you are.. It turned out to be a bad condenser. I read where you put in a set of unipoints and I have no idea how to " check " a condenser but thought I would toss it in the ring here...
Old Yesterday | 07:19 PM
acstephenson
That spark looks a little strong indicating the coil may be pulling too much current. Are you sure that Plymouth used coil is good? (It could also have introduced some fatal virus that GM cars have no antibodies for.) Something I do note in your image are what appear to be little bubbles in the coil wire insulation. I would be really interested in knowing the resistance of your coil wire; it might have been cooked by the coil's heat, This whole time I've had the feeling that we've been drawn down the ignition path but that it may be something else such as electric choke, electric fuel pump, or some other component that was damaged. At least you have eliminated a bunch of things that it ain't like bulkhead connectors, resistors, points and condenser. This thing still is screaming bad coil because these are the classic symptoms but it could be the coil wire.
Old Yesterday | 08:41 PM
SledgeHammer 2.0
I tried both coils, they both had the same spark, but no guarantee that the other one is good. I do have a car with a performance coil I can try.
A couple of years ago my bulkhead connector fried out and I put an engine and under dash wiring harness in it, so I think the wiring is good. I haven't replaced the tail light wiring harness. I don't have an electric choke nor a electric fuel pump. I will measure the resistance and get back, This car is wearing me out. I have owned it since 1988 and it's been a great car up till 4-5 years ago.
Old Yesterday | 10:05 PM
anyChevy's Avatar
anyChevy
That timing is pretty conservative, If that’s with vacuum plugged, I would try 36* total, which should give you 16* initial and see if it likes it.
I don’t think it’s the root of the problem, but can’t be helping.
Old Today | 05:54 AM
acstephenson
I've had one other thought (and it fits with my psychic tingling that we've been looking at the wrong stuff): All of this could be nothing more than a poor/broken battery or ground connection around the battery itself --- especially the smaller cables. These batteries (especially the non-AC cars) can be a pain to get in and out and it would be very easy to damage or fail to tighten a cable in the process. Measuring voltage across the battery while it's running might also provide a clue.
Old Today | 09:58 AM
After38Years's Avatar
After38Years
I would look very closely at the path from the points to the coil. The breaker plate is moving frequently during startup and driving (especially if you are having misfires) If you tested with a jumper from the points to the coil, did you disconnect the existing coil wire at the points or just parallel it with the jumper?
Old Today | 10:51 AM
MelWff's Avatar
MelWff
Any chance you have an electric choke?
To Messed up my C2 again, Driveability)
