Hi Idle - Need ECM rework
The IAC control is rather complicated. This is only a brief summary: The idle speed is not really controlled above 1.8 mph. Otherwise, the IAC will follow the throttle and will be parked in an intermediate position while off throttle while moving (dependent upon coolant temperature and history, fan, etc). With the converter locked the engine speed will generally follow the vehicle speed (for a given gear). With the converter unlocked the engine speed will vary with the airflow through the throttle and IAC (and any vacuum leaks) and will also be influenced by the vehicle speed, gear ratio and converter slip (see the N/V ratio).
Here is a log from an 89 showing some example IAC behavior with respect to throttle position and vehicle speed. The car comes to a stop near the end of the log, however the driver almost immediately shifted into park (or Neutral) at 0 mph, causing the desired idle speed to increase by 50 rpm. The idle speed is only being controlled (PID control) in this region of the log.
https://datazap.me/u/tequilaboy/logs...08&axes=shared
If the rpm is consistently high (overspeed error), it may not enter PID control.
; PID ENABLE CONDITIONS
LC543 FCB 3 ; 1%, ENAB T/F IF TPS GT THRESH%
LC544 FCB 0 ; 0, DONT STORE NEW TPS IF ID DIFF VAL < THRESH
LC545 FCB 6 ; 1.8 MPH/3.2, ENAB IAC PID IF Vss > THRESH
LC546 FCB 4 ; 50 RPM/12.5. MIN RPM UNDERSPEED ERR TO ENABLE PID DURING TRANSITION DELAY
; IAC TARGET SPEED vs COOLANT TEMP
; Dissassemby of ARAP, LINES = 17
; TBL = .08 * RPM
ORG $052E ; RPM Deg c COOL
LC52E FCB 84 ; 1050 -40
LC52F FCB 84 ; 1050 -28
LC530 FCB 84 ; 1050 -16
LC531 FCB 84 ; 1050 -4
LC532 FCB 84 ; 1050 8
LC533 FCB 76 ; 950 20
LC534 FCB 72 ; 900 32
LC535 FCB 60 ; 750 44
LC536 FCB 48 ; 600 56
LC537 FCB 48 ; 600 68
LC538 FCB 46 ; 575 80
LC539 FCB 46 ; 575 92
LC53A FCB 46 ; 575 104
LC53B FCB 46 ; 575 116
LC53C FCB 46 ; 575 128
LC53D FCB 46 ; 575 140
LC53E FCB 46 ; 575 152
Running distance and running fuel counters added to the display (same log): https://datazap.me/u/tequilaboy/logs...08&axes=shared
Note: the above log is slightly misleading since the running distance was only displayed to two decimal places in the adx file that was used prior to exporting this log to csv. The running distance counter should increment every 2.64 feet (or 0.0005 miles), so iin reality it will ramp more smoothly than the steps displayed above.
Below 1.8 mph (2.64 ft/sec) you can expect the mpg to go to zero, which is coincidentally the entry speed threshold for PID control.
