How do I program a new C7 Key FOB
https://guide.carkeysexpress.com/hc/...g-instructions
LEARN PENDING PLEASE WAIT" after the 5 key turns and 10 minutes later "PRESS ENGINE START BUTTON TO LEARN." Since you are not getting to the second message it is possibly a low voltage glitch.
Measure battery voltage with the engine off at the battery terminals or in the 12v receptacle inside the hatch on the right side wall. You should see around 12.7 volts. If possible put the battery on a maintainer. The long procedure is 30 minutes or so.
Verify fob batteries are good - close to 3.3 volts and installed correctly.
First of all - make sure your new fob is the correct part number. Certainly 2014-15 fobs are not recognized by 2016-19 and vice versa since they operate on different frequencies. I don't know if the correct model year range fob with the "wrong" number of buttons will work:
Second - adding a fob is a safe procedure. Unpairing all fobs and then adding new can become a real problem.
To be safe - try the Programming with Recognized Transmitters procedure in your manual first. This will verify the key switch (which seems to work for you) as well as the steering column slot. If this works, you will add fob #3. If the procedure doesn't work you probably need a dealer, locksmith, or appropriate programming tool.
If you really want fob #1 and #2 then try the Programming without Two Recognized Transmitters which will unpair all fobs previously paired to the car and then pair the fobs you have to the car as #1, #2, #3 etc. in the order that you put each one in the steering column slot and press the lock or unlock button.
I have added fob #3 on a 2006 C6, 2014 and 2019 C7 with no problems (once I realized that the 2014 fob was incompatible with the 2019 and got the correct fob).
There are links to download owner's manual up in the G7 General | Sticky Threads area...
GL
Ron
