LS7 bubbling coolant reservoir + positive block test, but no smoke or overheating
Old May 10, 2026 | 10:57 AM
Andrea Nortes's Avatar
Andrea Nortes
Default LS7 bubbling coolant reservoir + positive block test, but no smoke or overheating
Hey everyone,
My name is Andrea. I’m from Europe and recently bought a C6 Z06 with an LS7. The car already had head work done by the previous owner, and before shipping one of the heads (passenger side) was repaired/reworked by BMS.
I’m trying to diagnose an issue and would really appreciate input from people experienced with LS7 failures, head gasket issues, cracked heads, etc.
Current symptoms:
  • Engine runs strong
  • No smoke from exhaust
  • No misfires
  • No overheating
  • Oil pressure is stable and normal
  • No metal/glitter in oil
  • No crankcase pressure/blow-by symptoms
  • Heater works normally
  • Coolant system builds pressure
  • Upper hoses get very hard after driving
  • Coolant reservoir bubbles from cold start
  • Coolant slowly pushes out of reservoir
  • CO2/block test is definitely positive
Additional info:
  • When I first received the car, oil had a sandy/light brown color, clearly with some coolant contamination
  • I changed the oil and coolant
  • Since then oil does NOT look like milkshake and oil level has not noticeably increased
  • I had to add around 1.5L coolant total over time
  • Cooling system pressure test did not reveal any obvious external leak
At this point I’m trying to understand what is statistically most likely on LS7s with these symptoms:
  • head gasket sealing issue?
  • cracked/repaired head?
  • sleeve/block issue?
  • something else?
I’m especially interested in hearing from people who had:
  • bubbling reservoir from cold start
  • positive combustion gas test
  • hard hoses
  • but engine still running perfectly normal
Would appreciate any advice before teardown.
Thanks.
Old May 10, 2026 | 01:46 PM
kkupec02's Avatar
kkupec02
Welcome!!!
Old May 11, 2026 | 10:02 AM
1Hotrodz's Avatar
1Hotrodz
Welcome Andre!
Your problem is most likely a head gasket failure and/ or worst case, a cracked Cyl. head.
Old May 11, 2026 | 11:23 AM
NORTY's Avatar
NORTY
What's your temp gauge read?
Old May 11, 2026 | 11:36 AM
Andrea Nortes
NORTY
, always normally 210-220 F
Old May 11, 2026 | 11:40 AM
Andrea Nortes
Originally Posted by 1Hotrodz
Welcome Andre!
I really hope will see the problem in the head gasket instead, a cracked cyl head
Old May 11, 2026 | 12:50 PM
hawkgfr's Avatar
hawkgfr
Sounds like not a great repair job before you bought it? and hopeful just head gasket....Bubbles in water usually mean air from combustion chambers getting in coolant passages...Also when moving temps should be 192 to 200 ish on the DIC...
Try to find someone with experience with those motors...
Good luck hope it turns out good for you...
Old May 11, 2026 | 06:02 PM
Corvette_Dez's Avatar
Corvette_Dez
Welcome to the forums. Beautiful car.
With the heads being recently worked by a reputable company, it's fairly safe to say it's just a head gasket sealing issue.
Old Yesterday | 01:20 AM
Moved to C6 Tech for assistance.
Old Yesterday | 06:13 AM
Spaceme1117's Avatar
Spaceme1117
Hopefully, it is just a bad head gasket. But there is the possibility of a cracked sleeve/block as well.
To see what the problem is, it will require removing the heads.
Whatever it is, it sounds like it is a very slow coolant loss.
Old Yesterday | 07:05 AM
Andrea Nortes
Yeah, not the cleanest repair history for sure. The seller told me one head was replaced/rebuilt before I got the car, but when I drained the oil upon receiving it the color was sandy/milky — meaning coolant had already been mixing with the oil while the car was being driven to the shipping point. Mileage checked out, so it happened en route.
What's interesting is that temps stayed perfectly normal the whole time — even on a warm day — never climbed out of the normal range. So whatever is going on, the cooling system is still doing its job keeping temps in check, just losing coolant somewhere in the process.
CO2 block test came back positive, and there's constant bubbling in the reservoir — so you're right, combustion gases are definitely finding their way into the coolant passages. The car runs well otherwise, no smoke, no misfires.
Good news is I found a shop with real LS engine experience. Planning to get it in there soon for a proper teardown and diagnosis. Will report back once we know what we're dealing with — hoping it's just the driver side head gasket and nothing deeper.
Thanks for the kind words, appreciate it!
Old Yesterday | 07:08 AM
Andrea Nortes
Thank you! Yeah that's exactly what I'm hoping for — fingers crossed it's just a gasket sealing issue on the untouched driver side head and nothing more sinister underneath.
Got an LS specialist lined up. Will update the thread once we're into it!
Old Yesterday | 07:11 AM
Andrea Nortes
Yeah, hoping for the best but preparing for the worst mentally — light blood only please!
You're right, whatever it is it's definitely a slow leak. No dramatic symptoms, just quietly losing coolant over time with bubbling in the reservoir and a positive CO2 test. Heads have to come off either way to know for sure.
On that note — has anyone here dealt with a cracked sleeve or block repair on an LS7? Curious what the real-world options are — Darton sleeves, full block replacement, or something else? And what kind of money and time are we realistically talking if it goes that direction?
Old Today | 07:35 AM
NORTY's Avatar
NORTY
LS7's ain't cheap.
Figure about $17 to $19 grand.
To LS7 bubbling coolant reservoir + positive block test, but no smoke or overheating
