how to set timing
Old Yesterday | 12:58 PM
newc2owner's Avatar
newc2owner
Default how to set timing
What is the procedure and values I am shooting for when setting timing and adjusting dwell time? I just rebuilt the carb and tuned that in so i figure I should check the distributor next.
Old Yesterday | 02:03 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Dwell specs are to be between 28° and 32°. I aim for 30°.
The timing is going to depend on a lot of things:
  • what engine you have,
  • what modifications have been done,
  • what fuel you buy,
  • how hilly your location.
If you provide everything you know about these basics you'll get a better idea of where to start. Timing is something where even "identical" engines can perform best with different settings.
Old Yesterday | 02:07 PM
barkingrats
Also be aware that after you work the timing for your situation, your carb may need to be readjusted. Timing affects carbs — carbs do not affect timing.
Old Yesterday | 03:13 PM
newc2owner's Avatar
newc2owner
327 no mods or anything. i usually put 91 in. i live in phoenix so no real hills or anything. I think its a 250 or 300hp version
Old Yesterday | 05:52 PM
SJW's Avatar
SJW
Dwell affects timing, so set dwell before timing. As already noted, spec for dwell is 28* to 32*.
My approach for timing is as follows:
You'll want initial advance plus maximum centrifugal advance to be around 36*, and for the centrifugal advance to all come in at or above 2,500 RPM. You'll need a dial-back timing light, or accurately applied timing tape to the harmonic damper, to measure this. This must be measured with the vacuum advance disconnected. Plug the vacuum hose while it's not connected to the advance can. Once you have this dialed in, let the engine return to idle, check the timing (with the vacuum advance still disconnected), and write down where the timing lands at idle. You can then set the timing at idle in the future to this setting.
Vacuum advance should advance the timing 16* and it should be all in at idle.
Test drive while listening carefully for any hint of detonation or pinging. Retard the timing incrementally if required to eliminate. Loud exhaust can mask pings.
'Hope this helps.
Live well,
SJW
Old Yesterday | 06:19 PM
R66's Avatar
R66
I'll offer some articles by one of the Gurus of GM who has sadly passed.
https://www.camaros.org/library.shtml
Go down to Timing 101 by JohnZ. The other articles are great too. Don't get excited as it is a Camaro Site. A Chevy is a Chevy for the most parts
Ron
Old Yesterday | 11:40 PM
Frank Condron's Avatar
Frank Condron
7th Gear
Thank you, Ron. I checked out the Hinkley link and immediately book-marked it. Anything John Hinkley touched (wrote about) is gold. Easy to understand and dead nuts correct. Frank Condron
To how to set timing
