[C2] 67 Corvette - Holley carb - fuel line to pump?
Let's see what others say.
Larry
The last time I needed the 90 degree elbow I purchased it from NAPA. But it should be available on-line as well.
Larry
first, the factory carb will have a rear metering block . Your carb has an internal metering plate, and as such the center to center distance between your fuel inlets is about 1/2” shorter than an “ original” Holley.
note the secondary metering block at my finger.
note, I am showing a ‘66 Chevelle 396/375hp carb (3613), but should be representative of a 427/425hp carb.
here’s a reproduction fuel line setup. This is by Fine Lines, but Inline Tube and others sell these.
note, these two feed lines are 5/16” IF…. Only 3/8” from the pump to the brass Y-block.
several ways you can go.
you can change your carb fittings to 5/16” ( they are probably 3/8” on your BGrant carb.),
OR
Some of those hardline suppliers, IIRC, offered a set that uses 3/8” dual feed lines…
At least one of those same companies also offered a shorter line set to work on a carb without the rear metering block ( such as yours)…
I forget who, and it’s been 12+ years since I was looking.
now, as for the fuel pump…. Again, this is based on a 66 and 67 Chevelle (396/375hp L78).
the ‘66 used a 90degree brass elbow, npt pipe thread in the fuel pump and 3/8”IF output vertically to the main feed line up to the brass Y-block.
I forget the brand ( Weatherhead? Edelman-Plews?), but here is an elbow. Note, you cannot thread this fitting into an 3/8” IF threaded fuel pump, it must be 1/4” npt.
note the 3/8” IF flare seat, hard to see the npt male threads.
for ‘67, the fuel pump changed and featured a horizontal 3/8”IF seat in the pump itself ( no more separate adapter “ elbow”), and the line itself had a 90 degree bend at the bottom where it exited the pump and turned up to the carb.
Once again, this is based on my Chevelles, but should be similar to an L72 Corvette.
one finally note, it appears you are using the factory cast iron intake.
ALL the dual feed Holley carbs came on Aluminum high rise intakes, which are slightly taller than the cast iron, so there may be fitment issues for the repro line using the shorter manifold.
