Autocrossing & Roadracing Suspension Setup for Track Corvettes, Camber/Caster Adjustments, R-Compound Tires, Race Slicks, Tips on Driving Technique, Events, Results
Manual Exterior door release.
Old May 10, 2026 | 09:17 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Default Manual Exterior door release.
Next question in my track car build.
Is there a clean and simple way to have a manual exterior door release on a C6?
Im removing the electric switch(s) in the door. And need a way to open the door from the outside in case the driver is unable to. I'm leaving the manual interior release(s) on the floor in their stock locations.
Old May 11, 2026 | 07:21 AM
davidfarmer's Avatar
davidfarmer
I pulled the manual release cable through to the outside of my car. I don't have a photo handy but I'll get one when I unload.
Old May 11, 2026 | 03:35 PM
shuyberss's Avatar
shuyberss
Cruising
I pulled the manual release back for the drivers side rear and the attached it to the roll bar. I used a roll bar clamp with a tab and a hole in it
Old Yesterday | 01:33 PM
davidfarmer
mine exits in the OEM door pull area, just pull the red tab
Old Yesterday | 01:34 PM
davidfarmer
Old Today | 07:59 AM
Stamanti's Avatar
Stamanti
I picked up a second interior release lever off of ebay with cable and swapped out the pull cable for a second interior style release lever, that I presently have heavy duty zip tied to my cage. I'll post a photo once I unload, but I've been pretty happy with this setup.
To Manual Exterior door release.
