C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
2007 z06 clutch not comming up
Old May 11, 2026 | 04:05 AM
romandian's Avatar
romandian
Default 2007 z06 clutch not comming up
car has been sitting. on first drive clutch stuck to the floor. after i pulled it up it was fine. same happened several times. then it it started sometimes to come up, but not all the way (maybe 1-2" short), in between it was normal. now, after about 50-100 miles, its good. no problems.
im very curious what goes on mecanically/hydraulically to make the clutch act like that and then to "fix itself" (hopefully). i read a lot and talked to people, not really finding an answer, speculations ranging from spring/excenter on pedal to neccessary clutch replacement.
thoughts?
Old May 11, 2026 | 04:45 AM
Too-Fast's Avatar
Too-Fast
Active Streak: 90 Days
2024 C6 of the Year Winner - Modified
There is a service bulletin/recall that was issued on the C6 for the clutch master cylinder replace. Your master clutch cylinder needs to be replaced. Do a quick search on the Forum or Google and you will find all the info you need.
Old May 11, 2026 | 05:53 AM
Spaceme1117's Avatar
Spaceme1117
This. GM made a revised clutch master assembly. The updated part has a black reservoir; old part has a clear reservoir.
Pretty easy to replace. Remove front driver's side wheel. Remove wheel well access panel. Disconnect connecting rod from clutch pedal inside the car. Disconnect clutch line going to master; it has a clip and uses a quick disconnect that has a valve that will close when not connected. Undo two nuts/bolts securing the master. Remove and replace with the new master. Re-install everything.
The new part comes pre-filled with fluid. And the hardest part is getting the clutch lines re-connected. Needs a bit of force and is somewhat difficult to get leverage in the small space. You will know the lines are connected once they make an audible click.
I replaced mine a couple of years ago. Took about an hour.
Old May 11, 2026 | 10:41 AM
dmuellenberg's Avatar
dmuellenberg
This could also be the result of dirty clutch fluid and the fix may be as easy as replacing the clutch fluid. Do a search for 'Ranger method' which details the process of replacing the fluid. I would do that first. I have a 2006 Z06 with 235k miles on it and have never replaced the clutch master assembly.
Old May 11, 2026 | 10:54 AM
Landru's Avatar
Landru
As stated ablove, replace 'old' original MC w/ revised replacement.
This clutch pedal nonsense will not happen again.
Old May 11, 2026 | 11:23 AM
Z.06's Avatar
Z.06
I will disagree with all of the above and state that sometimes the above potential solutions do not fix a low clutch pedal or one that sticks to the floor. I tried them all with zero success on my 2008 Z06. Rangering the clutch fluid, revised clutch master assembly (black reservoir). hiring a dealer to bleed the clutch hydraulics, and the only thing that fixed mine was replacing the whole assembly with an aftermarket clutch. I will say that the only time my clutch pedal would sink partway or fully to the floor was to get the clutch really hot, which only occurred when running my car on the track. This was not caused by excessive shifting or any slippage of the clutch; it was driven by heat even with no shifting. I now have a Monster LT-1 twin clutch and the problem has never recurred.
Old May 11, 2026 | 11:31 AM
NORTY's Avatar
NORTY
Do this first.
Impressive!
Old May 11, 2026 | 03:51 PM
jb78L-82's Avatar
jb78L-82
Absolutely do the "ranger method" FIRST before anything else! It is literally so easy to do AND costs almost nothing but brake fluid, a very small amount, no less.
HINT: Exchange the Clutch brake fluid YEARLY with the ranger method and MANY (not all) clutch issues will be prevented........
Old Yesterday | 02:58 PM
keithhogan's Avatar
keithhogan
The clutch master cylinder failed on my 2006 a couple of months ago. No warning. Went to the floor.
Only 20k miles on the car.
To 2007 z06 clutch not comming up
