Sponsored by: Wheel Design
Another Idle Creep Disabled and Even/Odd Gears Only
Old Yesterday | 08:56 AM
op z's Avatar
op z
Default Another Idle Creep Disabled and Even/Odd Gears Only
I don’t drive my car as often as I’d like to and only have 6000 miles on my 2022. In recent weeks I noticed slight surging from a complete stop but blamed it on interaction of my Soler controller with the DCT controls. Yesterday the surging became more violent and caused the car to stall. This happened a few times over a couple miles. I pulled into a parking lot turned the car off and cycled the accelerator from 0 to full throttle a few times. When I attempted to return home I found the troubles had only gotten worse with surging and stalling after each stop and even or odd gears present. After finally getting home I left the drivers door open and gave it a rest.
This morning the cel remained lit and my scanner showed a P0700 code with one other code that I failed to note. I had a similar incident back when the car was less than a year old. That incident was a trans high temperature with reduced power output(I believe). I cleared that code with my OBD scanner and the problem never returned. Just as I did before, I cleared the code and drove it around the block. CEL was cleared and surging stopped.
I think if there were actually a problem with the DCT the code might be cleared but the problem(surging and stalling) would continue if there were actually a problem with the DCT the DCT. It seems the C8i s a very “glitchy” car due to all the interacting microprocessors. I will update this thread if the problem returns, but I think it is unlikely.
i would recommend keeping and scan tool in the car at all times so that you can clear codes and avoid being stranded in the middle of nowhere with a glitchy car that only needs to have some DTC codes cleared. I follow the forum pretty regularly and don’t recall anyone clearing a code and causing damage to their car or having the dealer give them trouble for doing so.
Old Yesterday | 09:10 AM
RKCRLR's Avatar
RKCRLR
My concern with clearing a code would be that the problem is gets pushed out beyond warranty to a point where clearing the code no longer fixes the symptoms. On the other hand the dealer may do the same thing or misdiagnose the problem and do a bunch of unnecessary work.
Old Yesterday | 09:24 AM
Andybump's Avatar
Andybump
If the problem is active, the DTC will come back right away. That's actually how their diagnostic procedures are written for the most part. A remedy is attempted, such as a Hydraulic System Flush, the DTC is cleared, if it does not come back, the procedure is terminated. If it comes back, then the tech proceeds to the next "remedy" - maybe replacing the filter or fluid - whatever the procedure calls for, all the way up to replacing a component (valve body) or the transmissions.
I guess you know by now, you should be recording the codes before you reset. P0700 conveys no information - the its the request to illuminate the MIL on the DIC. The other code was the important one. Also, codes remain in history for a while, but not forever. If this were happening to me, I would be taking it to the dealer. There is a good chance you masking a problem that needs to be addressed - not always - but I would want it checked out.
Old Yesterday | 09:54 AM
Ltngdrvr's Avatar
Ltngdrvr
Yes, and on a 2022 car, you only have a year or less of warranty coverage for the drivetrain left, soon a possibly very expensive repair may be all on you.
Has the transmission servicing been done according to the maintenance schedule???
Old Yesterday | 04:04 PM
ZORANGE's Avatar
ZORANGE
I highly doubt the Soler controller would affect the DCT "controls" in any way.
Old Yesterday | 04:40 PM
op z's Avatar
op z
DCT maintenace has been performed per GM requirements
Old Yesterday | 04:57 PM
superramvette2's Avatar
superramvette2
so the problem is the p0700 is just the code to trigger the CEL. The other code is what matters and once you clear it can no longer tell what is happening. But I get it you needed to get home and I’ve done this myself. The most common failure is valve body followed by parking pawl but if you are moving when this all happens and had one gear side (even or odd) it’s usually VB in my experience but without the codes it’s hard to tell. It will probably come back but not always. Sometimes you can try to spearhead this with filter/fluid and flush procedure assuming it’s a VB issue and you may get lucky. The parking pawl issue will likely get worse but this is more rare and the car won’t shut down or thinks it can’t go into park.
Old Yesterday | 04:59 PM
EvanD's Avatar
EvanD
CF Community Team
Meaning? You drained and filled the transmission and have not replaced the transmission filter?
Old Today | 08:54 AM
op z's Avatar
op z
Yes
Old Today | 09:02 AM
op z's Avatar
op z
As predicted by some here, the problem came back rather quickly. I tried to get a screen shot of the DTC's but failed to save it. I will update this thread to provide it later this morning. I have an appt. to get it in to the dealer for diagnostics tomorrow. Hopefully the trip to the dealer will be uneventful. When the car is jerking and stalling at intersections it makes every drive all the more stressful. With my car coming up on 5 years and on the original battery I was thinking that this might be the culprit. The voltage was at 12.3 volts just before it went squirely yesterday. Has anyone had a recurring transmission DTC that was caused by a low battery voltage? I normally keep the car on a tender and never have problems starting it.
Old Today | 09:14 AM
Andybump's Avatar
Andybump
How did you measure the 12.3 volts. Using the "battery voltage" info tile on your DIC. What were the conditions when you did that? Was the engine running?
The voltage on the DIC, called battery voltage, when the engine is running, is really system charging voltage (the manual does not tell you that). But that voltage can normally vary between 12.5 v and 15.5 volts depending on the battery state of charge, electrical load, and the charging mode that the ECM selects. You cannot determine if the battery is failing from reading that voltage when the engine is running.
You can put the ignition in service mode, without the engine running and read the voltage that way, but just be aware that is not a no-load reading. With the ignition in service mode and the engine off, the car systems are fully awake and it is drawing at least 10 amps - I have measured that. My battery is new and it reads 12.1-12.3 volts under that condition.
A low battery can cause a problem that seem unrelated, like setting of DTCs etc. And while the car is supposed to issue a low battery message of some sort, that does not appear to be reliable. Many (but not all) have reported a battery failure with no prior warning or message. The best way to determine that is have the battery load tested.
Old Today | 10:30 AM
op z's Avatar
op z
The 12.3 was through the OBD port with the car running.
Old Today | 10:34 AM
op z's Avatar
op z
Turns out I didn't lose the screen shot yesterday. Different DTC's yesterday than today.
To Another Idle Creep Disabled and Even/Odd Gears Only
