Auto hold?
I'm for pushing the park button and it's available now.
Now, in case one thinks otherwise - here is the explanation from the manual:
"When the vehicle is stopped on a grade,
Hill Start Assist (HSA) prevents the vehicle
from rolling in an unintended direction during
the transition from brake pedal release to
accelerator pedal apply. The brakes release
when the accelerator pedal is applied. If
the accelerator pedal is not applied within
a few minutes, the Electric Parking Brake will
apply."
From this explanation, you can deduce that what is happening is it applies the regular brakes first, but if sit on the hill too long that way - it does apply the electric parking brake.
Josh Holder: ".......the clutch engagement is controlled by hydraulic pressure. We apply pressure to the clutches which is how much friction they are applying and how much torque is being used to creep the car forward and that is a function of brake pedal pressure. Its not just on – off, because that would make it very clunky and awkward driving experience. So the more firm you are on the brake pedal, the less clutch pressure we’re applying. As you back off the brake pedal we’ll start applying more clutch pressure so the car’s ready to move like a torque converter automatic transmission even though this is completely different. So it operates the way people expect in automatic drive mode.”
Funny, my 2025 Honda Civic Hybrid has all that, Auto Hold, Adaptive Cruise Control, Lane Keep Assist, etc.... Do love the Auto Hold.
That's my guess. With the current C8 design, selector in D, as the drive release the brake pedal, the clutch slowly starts to engage so that the car starts to creep forward as it would with an automatic. This happens before any throttle is applied. At that moment, the clutch is actually slipping as the car comes up to speed enough to fully engage without lugging the engine (about 5-7 mph). An auto hold feature, designed specifically to apply brakes automatically so the driver does not have to apply the brake pedal, would complicate this. Would it disable the idle creep feature during auto hold, or would it just hold the car and allow the clutch to slip? I'm not saying that an approach could not be worked out, but it might be a little clunky.
When the hill start assist kicks in, it actually is a little clunky right? You must push the throttle a little harder, and then when the brake releases it starts abruptly. I think a start from auto hold would be the same way.
At least I enjoy what I'm driving.
(though my manual C5 doesn't... such progress
