Need help 85 corvette fuel pressure very weak
Old Yesterday | 12:50 AM
Hiltsjr42's Avatar
Hiltsjr42
6th Gear
Default Need help 85 corvette fuel pressure very weak
This is the fuel pressure after 5 min of applying 12v from batter to pin B at the sending unit , so far I’ve replaced fuel pumps with multiple different pumps , regulator, filter, injectors, sending unit , relay and harness? I can hear the pump prime & the relay click loud and clear when turning the key but I only get a squirt out of the sending unit itself less than 1 psi. if I apply 12v long enough eventually it will build to 40psi & hold. the fuel seems to have trouble leaving the sending unit itself if I unplug the feed hose it squirts just a little bit of fuel out the tank. Any ideas? I’m at a loss right now don’t know what to do
Old Yesterday | 10:20 AM
merc49's Avatar
merc49
Did you eliminate the pulsator in the tank. The orings in it go bad and leak. I would apply twelve volts at the connector but first take off the pressure line and put a longer hose into a bucket and see what kind of flow comes out. Be careful of course with gas and jumper wires. I would crank the engine while doing this test to be safe. If you get a high flow then, reinstall the line at the tank and check for flow at the pressure line where it hooks up to the engine. Again being careful, put the line in a bucket, and check for strong flow there. You have to eliminate one thing at a time. Are you putting new pumps in as replacements? Are you sure the socks at the bottom of the pump is clean? Theres a bunch of things it could be but this is what I would do as a start.
