Can you ID this suspension part for me.
Old Yesterday | 09:16 AM
Hvymtlc5's Avatar
Hvymtlc5
Default Can you ID this suspension part for me.
2005 C6 with 60K miles. Noticed I was getting a clunk from drivers front going over small bumps. Took the wheel off and found the bushing under the spring in picture "worn". What is this called. Would it cause the clunking?
Old Yesterday | 11:19 AM
Hvymtlc5's Avatar
Hvymtlc5
UPDATE: Well - I think I figured it out. It is a spring perch or known as a height adjustment bolt. Don't think that would cause tire wear. I pulled the shock and it was bad so I think that and alignment will fix inside tire wear.
Old Yesterday | 01:13 PM
kevtheo1191's Avatar
kevtheo1191
These will also cause wear. As that rubber deteriorates, it will change the ride height in that corner, throw the alignment out and contribute to the tire wear. Just replaced all 4 on my car last year.
Old Yesterday | 08:14 PM
Spaceme1117's Avatar
Spaceme1117
Which lowering bolts did you go with?
Old Yesterday | 08:22 PM
kevtheo1191
I put factory style ride height bolts back in. Roads are too garbage around me to be very low.
https://a.co/d/09fwP4FB
Old Yesterday | 08:28 PM
Spaceme1117
Thanks for the link. Probably need to change mine as I still on the originals.
I purchased some lowering bolts that have solid Delrin pads but never installed them. Read that a lot of people find they can make a good bit of noise. This was a few years ago when no one was making factory replacement bolts.
Old Yesterday | 08:40 PM
kevtheo1191
I've had these replacements in for a year now with no issues. Front will come up a bit even at max low as the pads are thicker than stock. Id have to measure to see where mine are at in relation the where the fenders measure off the ground
Old Today | 08:15 AM
NORTY's Avatar
NORTY
OP~ Don't forget to lubricate those Heim joints on those suspension parts!
To Can you ID this suspension part for me.
