[C2] Back up Lights
Old Today | 11:29 AM
Six7390gt's Avatar
Six7390gt
2021 C5 of the Year Finalist - Unmodified
St. Jude Donor '25
Default Back up Lights
How can I check to see if my 65 was originally equipped with back up lights?
Old Today | 11:57 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Does the car still have its original wiring harrnes in the dash and rear? Back up lights was bundled with a day night rear view mirror as well
Old Today | 12:11 PM
Six7390gt's Avatar
Six7390gt
St. Jude Donor '25
I'm sure the dash harness is the original.
Old Today | 12:16 PM
Nowhere Man
Is the a plug that goes through the firewall for the back up light switch. I think it's dark green and black wires
Old Today | 12:49 PM
c2vettehead's Avatar
c2vettehead
got a day/night mirror? Not always indicative though.
Yea, wiring harnesses is a big indicator. But all that could be added.
Need a pop or buildsheet.
I personally don't care for 65/66 backup lights. Dual red tails looks cooler IMHO.
Old Today | 12:57 PM
Nowhere Man
the pop would not tell you that and no build sheet for 66
Old Today | 01:41 PM
Six7390gt's Avatar
Six7390gt
St. Jude Donor '25
It has the day/night mirror, but it has 4 taillights.
I'm looking over this schematic and I see the back up light wiring on pages 1, 2 and 4. It looks like the Black and light green wires that go to the back up lights just go thru the standard bulkhead connector, but the body connector only has the black and light green wires if the car has back up lights.
I need to order a dash wiring harness, and need to choose between the with or without back up light harness. I want to replace the harness with the same type that came with the car.
If the car came with back up lights, someone would have wired the additional lights outside of the wiring harness - and the harness with back up lights should work with my existing setup. If the car did not have back up lights and I order the back up light harness then my setup would not work.
Should there be a switch on the shifter or transmission to activate the back up lights?
So - what is the best way to determine which harness is currently in the car? Check the wires coming out of the body connector, or ???
Old Today | 01:48 PM
Vet65te's Avatar
Vet65te
Gary - I believe both my 65's originally had BU Lights. Both had been converted to 'All-4 Red Brakelights' before I got them and I kept them that way, because I like having 4 versus 2 red brakelights.
There's an 'L' shaped connector at the firewall, drivers side of the distributor that is normally used for 65s with Backup Lights. Pics are from both my 65s, but wire colors are off due to years of
previous owners spray painting the engine compartment.
Mike T - Prescott AZ
Old Today | 02:20 PM
Six7390gt's Avatar
Six7390gt
St. Jude Donor '25
Thank you Mike!
I don't see that connector. Does it come thru the firewall as part of the harness or separately?
Old Today | 02:44 PM
Vet65te's Avatar
Vet65te
This pic shows it is in the harness that comes through the large rubber grommet and the twin connector for BU Lights should show itself just inches from where the main bundle emerges...if yours had BU lights.
Old Today | 04:26 PM
Six7390gt's Avatar
Six7390gt
St. Jude Donor '25
Thanks again Mike. That is very helpful. It's hard to get a good picture of that harness at the bulkhead. This is the best one I got. I do not have that connector, but I have two wires that have been cut off.
I can't see the color on one of the cutoff wires, the other is black.
I pulled the drivers side kick panel to look at wire colors, but they are still all taped up. I pulled the body connector down from the Z bar and got a good look at it.
If I'm reading the schematic correctly, this is the with back up lights body harness. There is only one empty socket in the connector, and the last wire shows black and light green.
Whew. That took way too long to figure out, but I'm comfortable ordering the wiring harness now.
Thanks again to everyone on this forum for your help.
Old Today | 04:54 PM
Nowhere Man
you can order the harrnes with back up lights and if you don't choose to add them just don't put the connector though the firewall. really its surprises me GM made two
To Back up Lights
