C7 ZR1 Discussion General ZR1 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
2019 ZR1 tire wear
Old Yesterday | 03:29 PM
douggreif12's Avatar
douggreif12
8th Gear
Default 2019 ZR1 tire wear
I just changed the original tires on my ZR1. All 4 tires wore the inside edge bad. !3,000 miles Is this normal or do I need an alignment? Other than the inside edge the tires looked pretty good. Any insight would be appreciated. Non ZTK
Old Yesterday | 04:08 PM
LPE385's Avatar
LPE385
If you mean 13,000 miles then I've seen plenty of Z06' and Grand Sports back in the day eat up the inside edge at those miles.
Old Yesterday | 05:34 PM
BELVIN20's Avatar
BELVIN20
You need a street alignment, the track alignment you now have will continue to eat the inside of the tires, many post on the forum about this issue, find a good alignment shop with Corvette experience and get a alignment.
Old Yesterday | 09:23 PM
kevin nevius's Avatar
kevin nevius
Yep, seems like a fairly common thing.
I just replaced mine too, and the inside edge wear (especially on the front tires) was pronounced. I have a street alignment, but had a little track and autocross time on them too - which I am sure contributed.
It's concerning though, the inside edge is the most hidden (especially if the car is lowered, like mine is). Something to keep an eye on for sure.
All the best,
kev
Old Today | 08:17 AM
douggreif12
8th Gear
Yeah, I didn't notice the wear until the car was up on my 4 post lift.
Old Today | 08:28 AM
NORTY's Avatar
NORTY
The "factory" spec for C6's, C7's, C8's is for negative camber. This causes more weight to be supported by the inside edges of the front tires. More weight means more wear. GM does this because it makes the Corvette turn more "assuredly."
It's more noticeable with wide tires, which the Corvette has.
To 2019 ZR1 tire wear
