How to check directional switch
I removed the steering coloumn from my 73 to replace the key warning switch.
I had to tear it apart to gain access to the switch.
replacement itself worked fine.
Before installing it back into the car, I would like to check all functions by using an ohm meter to check them at the harmonic connector.
For example:
which contacs have continuty when turning the turn signal lever to right and to left . What to check if the hazarf button is pulled, etc.
The only thing I was able le to check is the keywarning switch. It works fine.
I habe schematics but don't know what contacts are switched by Signal lever and hazard switch.
Thanks in advance!
Flashjack
Now I was able to figure out how to check the switches:
Could not test finally horn button, because coloumn is removed from car. But "G" has continuity to the horn contacts.
Best regards
Flashjack
Useful to check connections using Ohmmeter
