Has anyone had to have their parking brake drums cut?
Old Yesterday | 04:38 PM
QCKSLVR's Avatar
QCKSLVR
Default Has anyone had to have their parking brake drums cut?
After struggling for years with a parking brake that would barely hold at the last click, I finally pulled the wheels and rotors and adjusted the e-brake shoes. The brake now holds nicely at three clicks, but I’m now hearing a cyclical rubbing sound that I suspect is being caused by an out-of-round condition in one, or both, of the drums.
I have scoured the entire greater-Philly area trying to find a shop that still has a drum lathe, and have only found one - and they want $80 each to true them up! I may be old, but that sounds like a usury rate to me! If I can’t find something more reasonable, I may just back off
the adjusters a notch or two and live with the brake handle at five clicks.
Old Yesterday | 05:22 PM
lucky131969's Avatar
lucky131969
How did you go about adjusting the brake shoes? I would be very surprised if the rotor/drum was out of round.
Old Yesterday | 05:28 PM
Ltngdrvr's Avatar
Ltngdrvr
Heck man, new rotors cost less than 80 per.
Old Yesterday | 05:59 PM
QCKSLVR's Avatar
QCKSLVR
I believe there is only one way to adjust them: I removed the wheels, calipers and mounting brackets and then the rotors. Rotating the adjusters widens the shoes at the base. It may be that they were never set properly to begin with and now that I adjusted them correctly the shoe(s) are contacting a high spot on the drum.
Old Yesterday | 07:08 PM
Ltngdrvr's Avatar
Ltngdrvr
Actually, only one shoe, nearly a complete circle with the adjuster between the ends.
I would try re-adjusting it, let it take 4 or 5 clicks to set the brake instead of 3.
Old Yesterday | 07:53 PM
vito02's Avatar
vito02
I have never been able to adjust them to "3 clicks tight" without the shoes dragging.
Here is something to try prior to readjusting:
In a safe spot, coast at 15-20 MPH and apply the parking brakes to slow the car and seat the shoes to the drums at their new adjustment diameter. Allow to cool and repeat a few times.
Some manufacturers actually prescribe this as part of the parking-brake adjustment procedure.
BTW, I would sooner replace the rotors than trust someone to true them without removing excess material.
Old Yesterday | 08:15 PM
lucky131969
Well, it sounds like there may be two ways. The correct way, and the way you did it
Did you confirm any measurements of the drum to shoe clearance, or the overall brake shoe lining? Did you check for rotational resistance with the drum installed after cycling the brake 3 times?
Old Yesterday | 09:05 PM
QCKSLVR's Avatar
QCKSLVR
I don’t have a caliper to measure the diameter of the drum in comparison to that of the linings. I adjusted each side and felt for a little resistance when I reinstalled the rotors. That’s how I got to three clicks
Old Yesterday | 09:46 PM
lucky131969
ok...that's the problem. Just follow the service manual....piece of cake.
To Has anyone had to have their parking brake drums cut?
